Ever since I got my brandnew Connect3D X1900CF (1.2ns) out of the box, i’ve been having a strange problem.
I get a flickering /black screen now and then
I only get the flickering/
black screen when
vgpu is set to
1.41v or higher!
With
black screen, i mean loss of signal; my monitor goes black for a couple of secs and then is viewable agian, only to be followed by another black screen again.., and soforth and soforth...
But.... When I set
vgpu to
1.40 or
lower, the flickering/black screen flashing stops immediately!
Setting vgpu to 1.45v-1.50v results in an direct black screen, with a sporadic viewable desktop in between.
I've been testing this with AtiTool.
The problem occurs in 3d mode, but also in 2d mode (if vgpu is set to 1.41v or higher.)
Running crossfire enabled or disabled doesn't matter
Running with only one card in my systeem doesn't help either
At first, I thought it was VPU Recover kicking in, but I get it with vpu recover on and of.
It's almost like the GPU core of the master card itself cannot handle a vgpu of 1.41v or more.
My temps are good, the card is cooled with a full-cover EK waterblock , giving me 42 degrees Celcius stressed.
I'm still hoping to find a answer to this problem, because I'm limited to 1.4v on the GPU and I need more juice to take it over the 720MHz when overclocking.
My slave card (Sapphire X1900 XT 1.1ns) does 750MHz with 1.485v, so it would be nice to get those two cards in sync while overclocking.
