Your not sure if HFM is working?
You have to point hfm to the folder that contains the file FAhlog.txt.
A bit more detailed:
Click on Clients
Click on add a client
Name the Instance anything you want
Enter the shader speed in MHz
Go to Log Folder: and enter the path to the Fahlog.txt file
click OK
Your want to add a client for each gpu or cpu client your running.
use search to find each fahlog.txt file and make sure you when you search you include hidden files so you'll be able to find the fahlog.txt file for the systray client. And you have to unhide the file.
Click on Clients
click OK
