- Jun 23, 2009
- Michigan, USA
Don't know how I missed that, my bad.
As for the Motherboard, I have heard good things about the Rampage 2 Gene
he should have just done a core 2 quad or duo set up a few hundred cheaper to get a few better parts.
Uhhhh, you said 300W. I dont give a darn if it is a Corsair/PCPnC. If it doesnt have enough amperage on the 12v I wouldnt run it. Pretty simple what I said....300W is too low for an i7 and HD4850. Combined those will pull ~20A by themselves. Do the math 20a*12= 240W. You are also not taking into account the mobo power needs, and noise. I wouldnt do it, no frikin way. While it may turn on, I would never share that thought out loud.Uhh.. I said good quality.. Look at the Corsair 550w for example. Nowhere near the 30A you suggest, try 41A. http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
edit: Hell, the 400w Corsair in my HTPC is rated at 30A, and I'd trust that to run an i7/4850 system any day.
These numbers are peak power draw experienced over multiple runs of 3dmark vantage's third feature test (pixel shaders). This test heavily loads the GPU while being very light on the rest of the system so that we can get as clear a picture of relative GPU power draw as possible. Playing games will incur much higher system level power draw as the CPU, memory, drives and other hardware may also start to hit their own peak power draw at the same time.
Please also note that an i7 will use more power than the QX9770. So thanks for that article but its not close to accurate.
That was CPU load only. Do you see a pattern emerging?i7 920@stock with a GTX 280 which draws more than 4850, 211 watts at the PSU http://www.guru3d.com/article/intel-core-i7-920-and-965-review/18
lulz.. toms. They use a Kill a Watt meter to measure power for god sakes.
My PC running P95 Small FFT and Furmark hits 460W!!! Come on!
If they were worth anything, I would believe you. Im not trying to be difficult but Tom's is a joke. Any review site using a killawatt to measure power need their head checked. You have done an admirable job posting up your thoughts, but the supporting evidence came up short.I give up, measurable results obviously don't hold sway here
I am ALWAYS willing to share the correct information but to say a 200W PSU with likely 20A on the 12v rail being sufficient for an i7 + HD4850 with possibly a mild o/c is just bad advice. Im sorry. I cant go along with that.
