up to 2.36ghz...how far can kt333 bring me?
Maybe I dont know what Im talkin about.. but I dont think you should be going to 195fsb... (if you can).. with KT333... I have KT400, and someone told me not to go over 190fsb.. Maybe Im wrong though.. I dunno.. Im new.. :D
This has been discussed before and unfortunately, the TBred and KT333 are not 100% compatible. Almost everyone w/ a kt333 mobo and a tbred chip have problems running at FSB speeds from 182 and higher. Some ppl bottom out at 182fsb, I've been lucky enough to be able to run at 192fsb.
I was able to run at 208fsb w/ my pally but not with the tbred. I confirmed it when I replaced the tbred w/ my XP1600 last weekend and was able to run at 208fsb again.
If you can raise yor multi, you can still max out your o/c. I'm still able to run at 2640mhz but with at lower FSB speed.
Might be time for a mobo upgrade.
well what hardrive do you have? my western digital could do 185 only but i have seen maxtors that seem completly unaffected by any fsb change
Hmm, I've been running 192MHz FSB for about a week now no problems. I both Maxtor and WD HD's.
I can't go out of spec at all or my Maxtor corrupts. If I go to 167 , I get a file missing or corrupt when windows tries to load.
hkgonra, when I have had that problem usually it is a memory problem and not a hard drive problem. Have you checked you memory and it's settings, try memtest86 on it at 167 FSB, and see what it tells you.
I tried memtest on it but not over 166. I have Mushkin pc3200 it should be ok shouldn't it ? I thought mushkin was top-notch stuff ?
