UPDATING BIOS
Russam
Hi all,
I have an xfx 750i sli MOBO and i'm tryiing to update my bios. I've downloaded the update and its a 113 file extension. How do get this update to run? All help is greatly appreciated.
Russam
redduc900
Inactive Moderator
Portland, OR
The latest BIOS update (v1.41) for the XFX 750i is available as an ISO, which is contained in the downloaded *.zip; file name MB-750I-72P9_141.zip.
R
Russam
BIOS
s is it just a case of copying to cd and booting from cd in bios?
R
Russam
I've now tried what i suggested in the post above. When i boot from the dvd drive at come up loading windows 98 ide 4 channels supported.
Then after a small pause it says no drives found.
A Abort R retry.
This is so confusing
redduc900
Inactive Moderator
Portland, OR
You need to burn the ISO to disk and make it bootable. Then you need to change the boot priority in the BIOS, so your optical drive is the first boot device. You can use a program like ImgBurn to burn the ISO...
http://www.imgburn.com/
R
Russam
BIOS
Hi reducc900, sorry for being a pain in the but. I've used imgburn, nero and poweriso, i have burned the image to three seperate disks, and neither of them work. How exactly do i make the cd bootable?
Sorry again.
OnDborder
Senior Member
HOT 'n Arizona
Welcome to the Forum!:welcome: http://www.ocforums.com/showthread.php?t=491697 Russam
Personally, I'd read up on flashing the bios a little more.
If your flash goes bad,, you are up the creek without a paddle.
Why again, if I missed it, are you needing to flash the bios?
If it's a learning experience thing, do some homework.
Flashing a bios is a little riskier than burning a iso.
