- Nov 2, 2009
- Czech Republic
That and also they are easier to remove and dont need to buy new clamps every time you redone loop.Compression fittings add a lot of cleanliness to the case, and as far as I can tell are usually more secure, BUT, you can't ever really tell in advance if a tube is slipping off or something... you just have to trust them.
And you dont need to fiddle with screwdriver inside your case.
As for tubing slipping from compression fittings i doubt there is even someone strong enough here to pull them out if correctly secured
