hey, after killing my last athlon 1.2 gig i'v decided to get a new fan for when i get a new chip. The problem is that while taking off my last hsf (super orb) i broke that little clip thing that you hook the hsf over. So is there any fan that uses different connections or will it be ok if i just try and glue the little plastic bit back on?
thanx for your help
thanx for your help
