I have just built a new system (again!) and have reached a top limit of 3.98GHz.
My external frequency is at 265, my Vcore is at 1.500v, I have the PCI/AGP Locked at 66.33, and my ram at DDR 400 (1:1). My ram timings are 2.75v 2.5, 4, 4, 8, SDRAM Bank Inreleave is 4, I have the Performance accelerator enabled. Turbo mode Standard.
I have contacted Corsair as this Ram was tested on this board and they achieved 550MHz by using the same Ram settings as me and an external Frequency of 275 and everything else at default.
When I increase my FSB over 265 it becomes unstable even if increase the VCore upto or between 1.650v. I have temperatures of 42oC idle and at full load 49-51oC.
What more could I do or what settings should I change, would the Droop Mod make any difference?
Where I have set my VCore in the bios at 1.500v it actually reads in the hardware monitor part of the bios at 1.408v? Would I be better changing my CPU?
I'm looking to get my Ram to 550MHz and run the cpu at atleast 4.0GHz+,
