winTT1960 said:how much are his seperate systems?
and I dont want to spam just to get the post count, but I will try to get some posts.
Hello, as many of you may have known, I offer services and product that relates cooling your computer well below freezing points.
Labour for repairs/modification depending on job for single stage phase unit is $150-375 not including shipping or packing in general.
For cascade repairs, you will have to get individual quotes as nature of work can be quite complex.
As for product offered currently, here are some list of it.
I build custom phase unit such as single stage, single stage in few specific computer case, cascade of different sizes and uses, and some odd things people want to do as project. Pricing depdends heavily on component utilized, time involved. I try to get bit more than minmum wage for my effort though
There are 2 product line i have made as standard production run which reflects some saving due to that i am not spending as much time as i have to on totally custom builds
production line #1.
Single stage unit in sturdy 16 gauge steel with beautiful glossy black powder coating.
Component utilized: jinu117 condenser, Danfoss NF9FX, chilly1 evap or better.
Compatibility with: S939, LGA775, AM2.
Temperature range: expect 5-15c better temp on high heat load vs a well known production phase unit. Also a little more capacity to handle hotter cpu.
Noiselevel: Considered quieter than the WKPP.
Pricing: $650+packing($50 it gets double boxed with specialized foam)+actual shipping.
Options: $100 for LCD controller that reads temperature, turns on and off computer, controlls fan speed.
$60+ for powder coating other than glossy black.
Some samples first
production line #2.
Single stage unit in beautiful Lian-Li V2000
Case accessories added: Lian-Li EX-23 3 hdd bay addtion, extra wheel in mid to support the compressor weight better.
Pricing: $850+packing($50 it gets double boxed with specialized foam)+actual shipping.
$65 for side window from lian-li
$15 for EX-34 upgrade to enable 4 hdd support.
$10 for Plus II fan that keeps your GPU slot cool.
winTT1960 said:OK so I kinda got two options set in my mind, let me know what you think.
1. Jinu117 custom unit with Nf11 and slightly longer suction line and a black case. - 675 plus shipping/packing(guess of 50).... Lian Li V2000B from xoxide 223 plus 25 shipping, 248. Total ~973. Pros: Can be used for multiple systems, more powerful. Cons. takes up more space, less convienient.
2. Jinu117 Lian Li preinstalled unit. 850 plus shipping/packing (guess of 100)= 950. Pros: Looks nice and is compact Cons: limited to only one system and cannot change to a different case, less powerful because of smaller compressor.
What do you think, i cannot make the descision on my own.
winTT1960 said:If I were to get a seperate unit how would I route the suction if the unit was under the case. I am guessing I would have to do some drilling
winTT1960 said:This is what I am thinking, just buy a seperate unit nicely pimped out with NF11 and LCD and then later on buy me a new case. I think this would be the best performance and I wouldnt be constrained to a single PC case. Even though the pre-installed units are super nice, I just think I might regret it sometime down the road.
