All 3 of my GPUs have them right now. The PPD seems to vary. Sometimes it'll be 1500, but it's been evening out to about 4k on my 9800GT and 8800GT.
Please note, the behavior of this core is different from what you may expect. The following behaviors are NORMAL, and the points credit takes it into consideration:
Varying time per frame
Low GPU temperatures
Fluctuating CPU usage (somewhat higher than GPU core 11).
PS - What are your shader clocks? I'd expect a 8800GTS to beat a 8800GS yet mine are pulling 1.5k more ppd
That would fall under the varying time per frame category.
Don't complain. I'm cranking out a whopping 1100~1200ppd on my 8600GT with a p5902.Any body see one of these monsters yet? GPU project 5902 @ 1680 points!
This about 2500PPD at 9min 30 sec per frame on my 8800GTS 320MB. Not the best PPD out of the GPU wu's but better than most I have been getting lately.
I don't believe i've seen any of these yet. Can anyone confirm that these WU are available without using advmethods? None of my clients are setup with advmethods.
The link macaholic posted only mentioned advmethods so I assume that means its only beta right now.
Re: Announcing project 5900 and Core_14 on general FAH
by ihaque on Mon Mar 09, 2009 10:25 am
Since the EUE rate doesn't appear to be beyond expectations on this project and it seems that most of the performance issues have been resolved, I'm moving this project to general access on GPU Folding@home.
Announcing project 5902 (Core 14) on advmethods
by ihaque on Mon Mar 09, 2009 9:19 am
Project 5902 just went up on advmethods. It's similar to P5900, but with some tweaks that should improve WU stability. Like P5900, this project runs on core 14. P5902 is a duplicate of P5760, the protein L folding simulations, intended to validate Core 14. P5902 runs are 4x longer than P5900 runs, and points have been bumped in proportion.
WU's are worth 1680 points, with a preferred deadline of 3 days and final deadline of 4 days.
