OC the card
Welcome to the Forums!
Like the other Arcane said, a lot of factors are involved, like cooling, quality of the card's components, etc. I'd raise the core and memory separately to find the limit of each and test it with 3dmark2k1. Memory will give you graphical glitches (artifacts) when it gets too high. It's also where you'll see the most performance increase. The core will probably exit 3dmark or lock-up the computer when its clocked too high. Aim for 10% over the stock, but go up in steps of 3-5 Mhz. Then see how high it goes. It's also a good idea to test a couple of different drivers out. And record useful details like the clock speeds and which driver used, etc in the 3dmark project description so you can compare the score at various settings. Before you get lock-ups or artifacts you may notice the score getting lower instead of higher. This means its starting to get unstable and you should back it off a notch or two.
Some other things that help: disable vertical sync <under GF2MX additional properties in advanced display settings>, reboot between benchmarks, close anything that's running in the background before benching.
Get detonator drivers here:
www.guru3d.com
I wish you luck. And once you've found the sweet spot and have what you consider some good 3dmark scores, maybe you'd like to join the Overclockers 3dmark Team!! The link in my signature will take you to our site, or you can find us in the very 1st thread in the video/soundcard section. We're always happy to offer tweaking advice...
