What's your stepping and best OC
Paulster
Im trying to find out how good of an overclock i should be able to get and see who has some of the impressive overclocks and what steppings they are on.
Please state what cpu you have and what stepping it is, your motherboard, and your best overclock and also what cooling you are using.
My stats:
Motherboard: Epox 8k5a2+
CPU: Athlon XP 1800+
Stepping: AGOIA 4 0226
Best OC: 12.5 X 145 = 1812mhz and 10 x 179 = 1790mhz
Cooling: Alpha PAL 8045 w/ 80cfm Delta fan
My stats:
Motherboard: Epox 8K3A
CPU: Athlon XP 1600+
Stepping: AGOIA Y 0213
Best OC: 10.5 x 189 = 1984mhz (I run it normally for daily use at 181 x 10.5, 2V
Cooling: D-Tek Spir@l, Heater core, 1/2" Tygon, Eheim 1048
Using EPoX 8K5A2+, GeForce4 4200, Corsair XMS3000C2:
1. 1600+ AGOIA Y 0213 Blue core = 1906 MHz at 1.824 vCore
2. 1600+ AGOIA Y 0213 Green core = 1817 MHz at 1.792 vCore
The impressive part is not so much the MHz as the low voltages and corresponding low temperatures. As a result, I can easily use air cooling consisting of a Cooler Master HHC-001 and several fans on a rheobus.
Motherboard: Epox 8k3A
CPU: Athlon XP 1600
Stepping: AGOIA Y
Best OC: 1846 mhz
Cooling: AX-7 w/ 52cfm
My stats:
Motherboard: Epox 8K3A+
Stepping: AGOIA Y 0211
Best OC: 10x181 = 1810 Mhz @ 1.85V
Cooling: AX-7 w/ Panaflo H1A
