- Jun 21, 2002
Lets get a pic of that power supply. The problem that you could encounter with upgrading the power supply is that Dell uses proprietary connectors rather than standardizes ones, and an off the shelf PSU might not have the proper connectors to plug into the system. While they may use the same physical connectors, the electrical layout can be different. Adapters exist but again it has to be gotten right.
But let's not jump right to that. Posting a picture of the label should help us determine if the power supply can run a 2080. Also post pictures of any free connectors that might be PCIe 8 pin plugs. They are usually 2 rows of 3 pins stacked on top of each other, and then another 2 rows of one pin stacked that can either be separated or fits beside the others.
