- Mar 23, 2005
So I got my compnents yesterday and hurriedly put them together. i7 920, p6T, ocz ddr3 1600 ram, xigmatek 1283hdt/ocz freeze
first tested the ram with xmp at 1600 in memtest (stock cpu testing) 1.4 qpi/dram - 1.64 volts for ram - 24 hours perfect
then upped the bus to 170 and underclocked the ram to about 1400 - booted, ran some large fft and got temps in the 80s.
reset and dropped the bus to 160 (turbo still on cause I like it) to see if the temps would drop and plus i wanted the ram back at 1600 if possible and it wouldn't post.
hmmm....
brought it back up to 166 and set the ram at 1333 and then tried 1.2v on the cpu to see if temps dropeed and they did - 8 hours of large fft and simultaneous browsing, etc. and temps are at 70-73. Computer feels snappy.
Everything is auto except dram settings noted above, bclk and cpu volts.
My chip is a d0 so what do you guys recommend next...
Trying to drop the cpu volts again? What is average for 3.5Ghz? Is 1.2v more than i probably for 3.5 or should I leave it because it seems to work?
What's with the ram? i nmy history if ram tested at a certain speed at a certain fsb it would still do that speed at an increased fsb once the multiplier is adjusted. Wat do I need to adjust to try and get the ram to 1600? Or should I just leave it at 1333 because the difference is so minimal?
Thanks for any help. Wow is it a great time for Ocers!!!!
hmmm....
