Hello,
CPU: Athlon 64 X2 3800+
Motherboard: DFI Lanparty UT CF-DR (RDX200) - Latest BIOS flashed
Heatsink: Stock heatsink, as came with CPU
PSU: Seasonic 600W S12-600
Operating System: Windows XP Home SP 2 W
When running 3dMark05 the average FPS during the CPU test comes out at approx 1.1, whereas I've seen others with the same stock CPU getting results around 4-5 FPS and much higher CPU scores. Consequently, my overall 3dMark05 benchmark score is also very low - 6,300 running an 8800GTX (also stock).
I was previously running an X1800XL but had the same issue with that card and assumed that it could be the reason performance is so bad in games and benchmarking software (thus recently purchased an 8800GTX to try to relieve this problem) - changing the graphics card has not helped however so I assume it's either a problem with the CPU or motherboard.
I've tried the Microsoft X2 'hotfix' which is said to improve performance in most cases however it doesn't appear to have had any effect on the PC's performance at all.
3dMark05 Results: http://www.fileden.com/files/1/3dmark.jpg
http://service.futuremark.com/orb/resultanalyzer.jsp?projectType=12&XLID=0&UID=6940616
Thanks for your help in advanced
