XP Air-cooled Overclockers poll post here.
Lithan
Disabled
PA
Im curious. So to satisfy, here are the questions.
1. What motherboard, Cpu (including stepping), and memory you're using.
2. What heatsink and fan you're using. If fan's adjustable, what RPM you have it set at when temps are measured.
3. Ambient (room) temp, case temp (mobo reading), and on die temp at Idle and load.
4. FSB, Multiplier, Ram speed, ram settings, cpu and ram voltage, pci/agp divider.
5. I'd prefer if you used Prime95 to test stability as it's by far the best stability tester I've found. If anyone knows of any better programs please let me know. If you cant or wont use prime95, please say what tester you used and how long you ran it.
Namagomi
Disabled
Dallas, Texas and Tulsa, Oklahoma
1) Abit AT7-Max v1.1 Newest BIOS, XP2200 AIRGA (?) stepping 2x512 Corsair XMS 32MX8 PC-3200C2
2) Alpha 8045 with the crazy 80mm EHE delta on a TT fan adjuster, set to medium (4k)
3) No idea on ambient, but hotter than average. 34c case temp, 51c idle 56.5 max temp
4) 182 FSB 11 multi Ram @183mhz 2-3-4-3-1 (or whatever the fastest is) ram timings. 1.85 vcore 1.70 vram 5:4:1 divider funny thing is, i can run these settings all day, but i can't even boot into windows if i run in "Ultra CPU Decode" mode
5) Can run Sandra Burn-In or Prime95 all day and night, but freaking CPUStabTest dosn't wanna not crash.
NBK19
Kentucky
-1- ECS K7S5A Rev 3.1 - CheepoBios. AthlonXP 1700+ AGOGA stepping, 2 Sticks of Pc133 128mb of Samsung Ram
-2- ThermalRight Ax-7 "Not Lapped" With Vantec Torndao "84CFM" "5600 RPM "I think"
-3- Around 73F,25C 33C Idle - 37C Load
-4- 147, 11,Pc13 ,"Not sure", 1.76 "Not sure on Ram, "Not sure"
Prime95 is the way I go
RangerJoe
All that is Man!
Stillwater, Oklahoma
1. Epox 8k3a+ rev 1.2, xp1600+ AGOIA Y, 1x 512mb pc3200 cas2 XMS
2. Alpha PAL 8045 with 84cfm Sunon with rheostat (usually set to low (4k rpm))
3. Ambient is around 20c, case temps are 20c-21c. Idle -- 29c with fan on full, 31c with it on low. Load -- 38c on full fan, 41c with fan on low.
4. 192, 10x, ram settings...uhh..turbo settings for epox 8k3a+.. with 1T command rate. CPU voltage - 1.8v, vdimm - 2.6v, 5:1 divider
5. prime 95, folding, cpustabtest, sandra, 3dmark2k1SE...when i did test stability, i ran all of these for 12-24 hours..depending on the program...prime i ran for like 36 hours at this speed. never crashed once..BSOD's can kiss my butt.
edit..ram timings are....2-4-2-5-2
