Kit test – Joe
SUMMARY: Very good choice for a watercooling kit with reasonable price/performance.
The good guys at CoolWave were nice enough to send a CoolWave Stormcool III Kit to test.
The CoolWave Stormcool III Kit features
- Copper blocks for CPU, GPU and Northbridge chips
- Clips for Socket 478/370/462
- Radiator with 120mm fan
- Fully sealed waterpump/reservoir
- Fully charged with fluid
The kit comes securely packaged
in a foam container – note that it ships fully charged with fluid. The hoses have fairly difficult to remove clamps; the upside is that the user does not have to fill-and-bleed the kit.
The CPU waterblock
is all copper – these are fully sealed and users are not able to open these up; the GPU and chipset blocks are of similar construction – just smaller. The base
is well finished – I could not feel amy machining or polishing marks.
The parts
that ship with the unit allow mounts for all manner of CPUs, GPUs and Northbridge chipsets. The GPU is a clamp-like affair, which I have not seen before.
The waterpump
is encased in a plastic non-removable reservoir. There is a block object¹ on the power wire between the pump and the four pin plug – I asked about it but so far (communications problem??) I can’t get an answer as to its purpose – my supposition was that it’s an inverter and the pump is an AC unit, but that’s speculation on my part. This is the only part of the kit that does not have hose clamps; the hoses are silicone, which adhere very well to tightly fitted connections.
¹A number of readers suggest that it is for noise suppression – sounds good to me!
The CoolWave Stormcool III ships with a Yae Loon fan D12BM-12, a 120 x 25 mm unit that runs at 1650 rpm. I found it to be fairly quiet – I could not get a reading with a Radio Shack sound meter 8″ from the fan’s intake (the meter stops at 50 dBA).
One of the weak spots in entry level kits has been the waterpump – I ran this one for five days straight without a problem. This is not by any means a torture test, but at least it did not fail out of the box.
The CoolWave Stormcool III was tested on the CPU Die Simulator which gives results that are unaffected by motherboard influences. For this test, I only tested the CPU waterblock; I insulated the other two waterblocks to isolate their influence on results. However, with all three waterblocks installed, performance could be somewhat worse than indicated here. View the test results below as “Best Case”.
| Heatsink |
Die Temp
Ambient Temp
Delta
C/W
| CoolWave Stormcool III |
47.8 C
29.1 C
18.7 C
0.27
C/W = Delta / CPU Watts
