EVGA GTX 970 FTW Graphics Card Review
We’ve recently reviewed several NVIDIA GTX 980 based graphics cards here at Overclockers, and we came away impressed with their low power consumption, great performance, and “bang-for-the-buck” pricing. Today, we’re going to drop it down a notch and have a look at our first GTX 970. More specifically, the EVGA GTX 970 FTW. The factory overclock EVGA applied to the GTX 970 FTW is one of the highest we’ve ever seen, which leads us to believe EVGA is extremely confident in the headroom that’s available on these Maxwell 2 GPUs. EVGA also outfitted the GTX 970 FTW with their newest ACX 2.0 cooler, which performed terrifically when we reviewed the GTX 980 SC a while back. Let’s get going and find out what EVGA was able to accomplish with the GTX 970 FTW!
Specifications and Features
Looking at the specifications below, we can get a feel for the hefty factory applied overclock. The GTX 970 reference design cards are clocked at 1050 MHz base/1178 MHz boost, which means we have a 166 MHz base/189 MHz boost clock speed increase. Pretty impressive.
All of the latest NVIDIA technologies are at your disposal, including support for G-Sync and DirectX 12.
Specifications
  • Base Clock: 1216 MHZ
  • Boost Clock: 1367 MHz
  • Memory Clock: 7010 MHz Effective
  • CUDA Cores: 1664
  • Bus Type: PCI-E 3.0
  • Memory Detail: 4096MB GDDR5
  • Memory Bit Width: 256 Bit
  • Memory Speed: 0.28ns
  • Memory Bandwidth: 224.3 GB/s
Key Features
  • NVIDIA Dynamic Super Resolution Technology
  • NVIDIA MFAA Technology
  • NVIDA GameWorks Technology
  • NVIDIA GameStream Technology
  • NVIDIA G-SYNC Ready
  • Microsoft DirectX 12
  • NVIDIA GPU Boost 2.0
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA Surround Technology
  • NVIDIA SLI Ready
  • NVIDIA CUDA Technology
  • OpenGL 4.4 Support
  • OpenCL Support
  • HDMI 2.0, DisplayPort 1.2 and Dual-link DVI
  • PCI Express 3.0
  • EVGA ACX 2.0 Cooling
  • 1.215v+ Voltage Boost
  • 3-year warranty
Resolution & Refresh
  • Max Monitors Supported: 4
  • 240Hz Max Refresh Rate
  • Max Analog: 2048×1536
  • Max Digital: 4096×2160
Dimensions
  • Height: 4.376in – 111.15mm
  • Length: 9.5in – 241.3mm
  • Width: Dual Slot
Requirements
  • 500 Watt or greater power supply
  • PCI Express, PCI Express 2.0 or PCI Express 3.0 compliant motherboard with one graphics slot
  • Two available 6-pin PCI-E power connectors
  • Windows 8 32/64bit, Windows 7 32/64bit, Windows Vista 32/64bit
A quick look at GPU-Z gives us additional specifications worth noting. At the heart of the GTX 970 FTW is the NVIDIA GM204 Maxwell 2 GPU. The CUDA core count comes in at 1664, and the ROPs and TMUs show 64 and 104 respectively. The 4 GB of GDDR5 memory is clocked at 1753 MHz (7012 effective) and sits on a 256-bit interface. The base and boost clock speeds are confirmed as well, but we know from experience the actual boost clock will be higher than what’s reported here. In fact, we saw the actual boost clock settle in at 1392 MHz with an occasional spike to 1404 MHz.
evga_gtx970ftw (47)
Other than the stout factory overclock applied to the GTX 970 FTW, the other major feature is the ACX 2.0 cooler. The ACX 2.0 has several enhancements over its predecessor, which include two more swept design fan blades, a redesigned fan motor, and better magnets. EVGA touts the ACX 2.0 as being longer lasting, quieter, and capable of better performance when compared to their own ACX 1.0 and competitor brands. One of the best advantages the ACX 2.0 has over the competition is its low power consumption. Why is this important? The wattage the cooling fans use is calculated in the overall TDP that’s available, which is 145 watts in this case. The less wattage the fans use could equate to more overclocking headroom before the 110% power target limit is reached. Also worth noting is that the ACX 2.0’s fans will not begin spinning until the GPU temperature reaches roughly 60 °C.
evga_gtx970ftw (2)
evga_gtx970ftw (4)
evga_gtx970ftw (5)
Retail Packaging/First Look
The retail package does a good job of explaining what you’re buying into. As you work your way around the box, you’ll find a list of features, specifications, and some of the benefits of choosing this card over competitor offerings.
EVGA uses a plastic clam-shell to house and protect the GTX 970 FTW. The accessories sit on top of the clam-shell and include lots of documentation, a wall poster, the driver/utility CD, a case badge, power adapter cables, and a DVI to VGA adapter.
Photo op
Before taking an up-close look at the GTX 970 FTW, here are several pictures taken from various angles. As you can see, the GTX 970 FTW is comprised of a mostly black color scheme, except for a spattering of blue near the center of the fan shroud.
GTX 970 FTW Overhead View
GTX 970 FTW Side View
The EVGA GTX 970 FTW Up Close
Looking at the I/O area, EVGA opted out of the reference design’s three DisplayPort connections and chose to revert back to a single DisplayPort, one HDMI, and two DVI connections. This still allows you to use four concurrent monitors, but takes away the ability to use a tri-monitor G-Sync surround setup.
Display I/O
Display I/O
The GTX 970 FTW requires dual 6-pin PCI-E power leads, which should provide an abundant amount of power for a 145 watt card such as this. Along the top of the card, two SLI bridge connections are found for up to tri-SLI support.
Dual 6-Pin Power Connectors
SLI Bridge Connections
Once the ACX 2.0 cooler is removed, we can see the TIM was appropriately applied and making good contact with the GPU.
ACX 2.0 Removed
ACX 2.0 Removed
There are four heatpipes that travel the distance of the fin array and make direct contact with the top of the cooler’s base plate. There is no direct contact with the MOSFETs, VRM, or memory; but they should receive adequate air flow from the fans. The two 90 mm fans have 11 swept design blades that are said to run quieter and provide more air flow through the heatsink than the previous ACX 1.0. The fan motor has been upgraded to include a 3-phase/6-slot design, two ball bearings, and enhanced magnet strength. Below is a series of pictures showing the ACX 2.0, which gives you a good look at its design.
ACX 2.0 Bottom Side
ACX 2.0 Bottom Side
ACX 2.0 Bottom Side
ACX 2.0 Bottom Side
ACX 2.0 Bottom Side
ACX 2.0 Bottom Side
Fin Array Side View
Fin Array Side View
Fin Array Side View
Fin Array Side View
Fin Array Side View
Fin Array Side View
Fan View
Fan View
Fan View
Fan View
Fin Array and Fans, Shroud Removed
Fan and Fin Array Shroud Removed
Looking closer at the PCB, we can see the same 4-phase GPU power design used on the reference design cards. However, EVGA extended the PCB at the rear area, which is where you’ll find the two power phases dedicated to the memory. There is a metal stiffening plate attached to the top of the extended PCB area to keep the card from flexing.
4-Phase GPU Power
4-Phase GPU Power
4-Phase GPU Power
4-Phase GPU Power
Stiffening Plate Removed
2-Phase Memory Power
The GTX 970 FTW’s GPU power phases are controlled by an ON Semiconductor NCP81174 VRM module. EVGA added a second VRM (not pictured) found at the back of the card to provide additional power, which is an improvement over the reference design cards. Also found at the back of the card is an extremely small triple-BIOS switch that will require a very small pointed device of some sort to actually throw the switches.
GPU VRM
GPU VRM
BIOS Switch
BIOS Switch
Just as we saw on the EVGA GTX 980 SC, the 4 GB of memory comes from Samsung’s K4G41325FC-HC28 GDDR5 modules. Our previous experience with these memory modules resulted in excellent overclocking headroom, so we’ll check that out this time around too. The last picture below is of the NVIDIA GM204-200-A1 GPU.
Samsung GDDR5 Memory
Maxwell 2 GM204 GPU core
Performance and Overclocking
Test System
Test System Components
MotherboardASUS Maximus VII Formula
CPUIntel i7 4790K Devil’s Canyon @ 4.0 GHz
MemoryG.SKill TridentX DD3-2400 MHz 2x8GB @ 1866 MHz 9-9-9-24
SSDSamsung EVO 500 GB SSD
Power SupplyCorsair HX1050 Professional Series
Video CardEVGA GTX 970 FTW – Driver Version 344.65
CoolingEKWB Supremacy EVO Water Block – 360 mm Radiator – MCP35X Pump
We’ve got a good selection of comparison samples, which includes a R9 290, R9 290X, GTX 780, and GTX 980. We’ll adhere to the Overclockers.com GPU test procedure that’s been in place since the Haswell platform was released. If you’re not yet familiar with our methodology, then click on the link provided for additional information. For quick reference, below is the down and dirty version of what we do.
Minimum System Requirements
  • i7 4770K or i7 4790K @ 4 GHz
  • Dual Channel DDR3 @ 1866MHz 9-9-9-24
  • GPU @ stock and overclocked
  • Monitor capable of 1920×1080
Synthetic Tests
  • 3DMark Vantage – DirectX 10 benchmark running at 1280X1024 – Performance preset.
  • 3DMark 11 – DirectX 11 benchmark running at 1280X720 – Performance preset.
  • 3DMark Fire Strike – DirectX 11 benchmark running 1920X1080 – Standard test (not extreme).
  • Unigine Heaven (HWBot version) – DX11 Benchmark – Extreme setting.
Game Tests
  • Batman: Arkham Origins – 1920X1080, 8x MSAA, PhysX off, V-Sync off, The rest set to on or DX11 enhanced.
  • Battlefield 4 – 1920X1080, Ultra Preset, V-Sync off.
  • Bioshock Infinite – 1920X1080, Ultra DX11 preset, DOF on.
  • Crysis 3 – 1920X1080, Very high settings, 16x AF, 8x MSAA, V-Sync off.
  • Final Fantasy XIV: A Realm Reborn – 1920X1080, Maximum preset.
  • Grid 2 – 1920X1080, 8x MSAA, Intel specific options off, Everything else set to highest available option.
  • Metro Last Light – 1920X1080, DX11 preset, SSAA on, Tessellation very high, PhysX off.
EVGA Software – PrecisionX 16
For a desktop GPU software utility, EVGA offers up PrecisionX 16. Everything you need to overclock, monitor, and control the fans is readily available and easy to use. Depending on the actual graphics card installed, PrecisionX 16 has the ability to marginally manipulate the GPU core voltage. GPU core and memory speed can also be adjusted using the provided offset method. Fan speeds can be adjusted by simply using the slider on the left side of the main window or by accessing the fan curve option to base fan speed off of the GPU temperature. There are many other tweaks you can make with PrecisionX 16, so it’s definitely worth checking out.
PrecisionX 16 Main Screen
PrecisionX 16 was used to achieve a 24/7 stable overclock of 1300 MHz GPU and 1900 MHz (7600 MHz effective). That’s an additional 86 MHz over the already stout factory overclock. At that setting, the GPU boost clock was 1451 MHz. Actual boost clock came in right around 1468 MHz with occasional spikes as high as 1479 MHz. A 24/7 stable overclock means the settings are able to complete all our benchmarks with no stuttering, artifacts, or any other abnormalities. We’ll see if there is anything left during the “Pushing the Limits” section of the review; but for now, we’ll use this to obtain our overclocked benchmark scores.
HWBot Heaven @ 1300 MHz GPU / 1900 MHz Memory
3DMark Fire Strike @ 1300 MHz GPU / 1900 MHz Memory
It was a bit of an unfair fight to throw a GTX 780 Ti and GTX 980 in the comparison charts, but it’s nice to see how the GTX 970 FTW stacks up against NVIDIA’s top dogs. As we look at the synthetic test results below, the GTX 970 FTW had no problem beating out the GTX 780 and R9 290. The GTX 970 FTW traded blows with the R9 290X and wasn’t that far behind the GTX 980 and GTX 780 Ti. Excellent showing for the GTX 970 FTW here.
HWBot Heaven Results
3DMark Fire Strike Results
3DMark Vantage Results
3DMark 11 Results
3DMark 11 Results
Moving over to our game benchmarks, things look pretty bad for the red team here. The GTX 970 FTW swept the R9 290 and dominated the R9 290X in all but one of the benchmarks (Crysis 3). The GTX 970 FTW swept the field against the GTX 780 and held tight to the GTX 780 Ti and GTX 980, especially when overclocked.
Batman: Arkham Origin Results
Battlefield 4 Results
Bioshock Infinite Results
Crysis 3 Results
Crysis 3 Results
Final Fantasy XIV: ARR
Final Fantasy XIV: ARR Results
Grid 2 Results
Grid 2 Results
Metro: Last Light Results
Surround/Eyefinity Comparison
We ran five of our most popular game titles through our tri-monitor Surround setup at 5760×1080 resolution. Keep in mind, we keep all the game settings maxed out for our Surround/Eyefinity testing with each of the comparison samples at their stock settings. All of the higher-end cards tested here have 3 GB or more of onboard memory, which is why we see little difference between all the comparison samples. The GTX 970 FTW fell pretty much in line, just as it did in the single monitor testing above; and it managed to pull 30+ FPS in three of the five benchmarks.
Surround/Eyefinity Testing
Power Consumption and Temperatures
Power consumption numbers are quite astounding when you think back to previous generation graphics cards. With the GTX 970 FTW overclocked, the highest total system power draw was a mere 310 watts. A quality 500 ~ 550 watt power supply would give you plenty of headroom for overclocking both the graphics card and CPU. That’s pretty impressive when you consider the cost saving benefits over having to buy a high wattage PSU. Good stuff all round!
evga_gtx970ftw (63)
Power Consumption Test Results
Just as impressive as the power efficiency numbers is the performance of the ACX 2.0 cooler. Right on queue, the fans fired up near 60 °C and were almost inaudible when left at the auto setting. With the card overclocked and the fans set to their auto setting, we were able to keep the GPU temperature under 80 °C. If you don’t mind a little noise, setting the fan speeds to 100% should keep the GPU temperature well below the 60 °C mark. There really is no reason to put up with much noise because with the fans left on the auto setting, the temperatures will be kept in check nicely.
evga_gtx970ftw (64)
Temperature Test Results
Pushing the Limits
There wasn’t a whole lot of headroom left past the overclock we already had in place, but we were able to get an additional 25 MHz on the GPU and 50 MHz on the memory. This landed us at 1325 MHz base/1476 MHz boost for the GPU and 1950 MHz (7800 MHz effective) on the memory side. At this point, we were up against the 110% power target limit, and anything higher resulted in GPU core speed fluctuations. Still a good result though, and our 3DMark Fire Strike score increased another 129 points.
3DMark Fire Strike @ 1325 MHz GPU / 1950 MHz Memory
Conclusion
The EVGA GTX 970 FTW proved to be a great performing card that has many features gaming enthusiasts look for. Low power consumption, excellent cooling from the ACX 2.0, a massive factory applied overclock, and performance that puts it ahead of the AMD R9 290X in most cases all add up to the GTX 970 FTW being a serious contender for your next graphics card purchase.
The EVGA GTX 970 FTW currently sells for $379.99 at Newegg and the EVGA store. When you consider it’s the highest out-of-box overclocked GTX 970 there is, that’s an easily acceptable price. The price is even more justified when you still find some AMD R9 290X offerings selling for more than this card.
If you’ve been looking to jump into a Maxwell 2 graphics card that offers great performance at an affordable price, the EVGA GTX 970 FTW might be just what you’ve been waiting for. It’s an easy call this time around… Overclockers approved!
Overclockers_clear_approvedClick the stamp for an explanation of what this means.
Dino DeCesari (Lvcoyote)
About Dino DeCesari 230 Articles
Dino DeCesari was a pillar of the Overclockers.com community for over 13 years when he passed away suddenly in 2015. His legacy lives on through his hundreds of computer hardware reviews posted here. Dino spent time in the army as a Telecommunication Center Specialist and received a commendation medal. He had a successful 20+ year career in the automotive parts and technology industry, where he eventually bought and sold his own business. Once retired, he volunteered as tech support for a non-profit and his local school district.
Loading new replies...
Avatar of EarthDog
EarthDog
Gulper Nozzle Co-Owner
76,656 messages 3,361 likes
Been waiting to see one of these (970's) on the front page.
Nice review! (sorry I didn't get a chance to get its second edit in this weekend)
Reply Like
Avatar of Lvcoyote
Lvcoyote
Overclocked Moderator, Overclockers.com Lead Edito
1,473 messages 0 likes
No worries Joe, the wife makes a good backup....LOL
Reply Like
Avatar of NiHaoMike
NiHaoMike
dBa Member
1,927 messages 79 likes
What I find unusual is that big empty patch on the end of the card. Is that to give clearance for the fan on the reference cooler style version?
Reply Like
Avatar of Lvcoyote
Lvcoyote
No, the reference design PCB is much shorter. The reference cards use a bracket that hangs off the end of the card to mount the cooler's back end to.
Here is an example...
Reply Like
Avatar of ATMINSIDE
ATMINSIDE
23,912 messages 406 likes
Look at the back of the PCB, it isn't blank on both sides.
Reply Like
Avatar of Mandrake4565
Mandrake4565
Mr. Clean Senior Member
13,397 messages 9 likes
Reminds me of my GTX 670 reference. On the review, Lvcoyote very nice, it just reiterates how good these cards are for the money.
Reply Like
