Edit: 9/21/2020 – Our current testing procedure is here: https://www.overclockers.com/overclockers-com-gpu-testing-procedures-2018/
This article will serve as a reference for those who would like to compare results with our reviews, whether you are writing an article for the site or just testing the performance of your new GPU. The plan is to keep this article updated as changes in our testing procedures occur. On to the gritty details…
Table of Contents
Test Platform
(Updated: 09/2018)
Our test systems consist of mainstream parts since that is what the majority of people will be using, hence “mainstream.” This allows our results to be relevant to a wider audience, and also allows for that audience to repeat our tests to compare with their own systems. The required parts and clocks are as follows:
Test System Components | |
Motherboard | ASRock X370 Taichi, ASUS ROG Maximus X Apex |
CPU | Intel i7 8700K @ 4.7 GHz / 4.3 GHz Cache |
CPU Cooler | EVGA CLC 240 |
Memory | 2×8 GB G.Skill Trident Z 3200 MHz CL15-15-15-35 |
SSD | Toshiba OCZ TR200 480 GB (OS + Applications) |
Power Supply | EVGA 750W G3 |
Video Card | @ Stock |
Synthetic Benchmarks
(Updated: 09/2018)
Synthetic benchmarks are very consistent and easily repeatable, making them some of the best tests for direct card-to-card comparisons. We have dropped support for Unigine Heaven and Valley and will continue with 3Dmark Fire Strike Extreme and Time Spy.
3DMark – Fire Strike Extreme
- Fire Strike – Extreme setting
- “Include Demo” can be unchecked since it doesn’t affect the score
3DMark – Time Spy
- Default setting (you do not have to run the demo)
Game Benchmarks
(Updated: 09/2018)
We have updated our gaming suite to get rid of some of the older titles. Now all of the benchmarks are “canned” tests, making them as consistent as possible and more synthetic-like than typical gameplay. In general, we do our testing with the commonplace resolution of 1920×1080, all of the graphics settings maxed, and any manufacturer specific features disabled.
Final Fantasy XV
Final Fantasy XV Benchmark Link
Set “High” defaults, the in-game graphical options should match the following:
World of Tanks enCore
Link to World of Tanks enCore Benchmark
Set “Ultra” defaults, the in-game graphical options should match the following:
F1 2018
Setup the video configuration as follows using “Very High” defaults with TAA, AF X16, run Australia track and show the FPS counter. The video configuration should look like the screenshots below, then run the built-in benchmark located in the options.
Shadow of the Tomb Raider
Run DX 12 with “Highest” preset and RTX when available. The video configuration should look like the screenshots below, then run the built-in benchmark located in the options.
Far Cry 5
Setup the video configuration as follows using the “Ultra” preset. The video configuration should look like the screenshots below, then run the built-in benchmark located in the options.
Tom Clancy’s – The Division
Run DX 12 with “Ultra” preset with V-Sync off. The video configuration should look like the screenshots below, then run the built-in benchmark located in the options.
Ashes of the Singularity: Escalation
Run DX 12 with “Crazy” preset and GPU focused. The video configuration should look like the screenshots below, then run the built-in benchmark located in the options.
Optional Testing
(Updated: 09/2018)
The following are a few things that will provide additional value and detail to the testing but are not required.
Temperature
Measuring typical temperatures to expect and/or testing cooler performance.
- Record ambient temperature in degrees Celsius (preferably close to the intake fan of the GPU)
- GPU-Z, PrecisionX, Afterburner, etc. will be used for monitoring temperatures during the test
- Record the GPU’s idle core temperature in degrees Celsius after the card has been on and in the idle state for a few minutes
- Run Shadow of the Tom Raider and F1 2018 (5 laps) at the settings above and record the peak temperature in degrees Celsius with the default fan profile (other manual fan speeds can be tested as well).
- When comparing temperature results, they all need to be normalized to the same ambient temperature (Currently 22C).
System Power Consumption
Kill-a-Watt meters (or similar) are used for measuring at-the-wall system power consumption.
- Record the system power consumption at idle
- Record peak power consumption during the following two benchmarks: Shadow of the Tom Raider and F1 2018 (5 laps)
Noise
Sound level meters are used to measure dBA as a means to quantify noise and perceived loudness.
- Tested on an open bench, which gives the worst case scenarios.
- Minimize all external sources of noise: Turn off A/C, turn off ceiling fans, turn off TVs, turn CPU fan off or as low as possible, etc.
- Manually set fan speed in varying increments via software such as PrecisionX or Afterburner.
- Record sound level at each increment. Be sure to get readings within your meter’s most accurate dBA range, regardless of distance. The most affordable meters are accurate at high dBA ranges, meaning the meter will have to be placed close to a quiet source for an accurate reading.
- Readings can be estimated at dBA ranges outside of your meter’s capability to get estimated sound level at longer distances.
- Typical linear percentages cannot be used when comparing dBA measurements because dBA uses a logarithmic scale. So, the rule-of-thumb is every 1 dBA difference is roughly equal to a 10% difference in perceived loudness.
The following equation is used for estimation of sound level at different distances.
L2 = L1 – 20 * log10(r2/r1)
- L1 = Sound level at the reference distance
- L2 = Sound level at the desired distance
- r1 = Reference distance
- r2 = Desired distance
Multi-Monitor
Nothing changes here except the use of multiple monitors in AMD’s Eyefinity or NVIDIA’s Surround. All benchmark settings remain the same.
- Three 1920×1080 monitors are preferred for a total resolution of 5760×1080
Picture from complx‘s project log: RGD – Custom Built Surround Monitor Stand.
Conclusion
Nope, this definitely isn’t the “conclusion” of this article, it will be slowly evolving, just like our GPU testing procedures. We’ll post comments with changes as they take place, so be sure to keep an eye on this, the comments, and the forum thread for updates. We are always open to feedback and suggestions as well. So, if you think there is something worth testing that’s not included, then feel free to speak up in the comments below.
– Matt T. Green (MattNo5ss) / Joe Shields (Earthdog) / Shawn Jennings (Johan45)
Please leave any comments or suggestions in this thread.
Discussion
