- Apr 20, 2004
- JAX, Mississauna
Trying it is the only way to know if it will work out okay at your end.
RGone...
RGone...
In general you don't lower VCore and raise CPU_NB voltage to get stability. 1.362Vcore on that cpu is probably about correct, if not just a shade low for over 3.6Ghz.
RGone...
Well I was basing it off Dolks guide for the Denebs voltage of 1.25 with the x13. I might try dropping the vcore a bit and seeing if it is still stable because I think increasing the nb will surely add stability but with some heat and I am at 51c. Which voltage for the nb should I increase?
I've had my X6 1090T (OC'd to 3.8 for 24/7) regularly hit 70C when gaming/benchmarking and it's still going strong, also using a Hyper 212+ on it.
