Actually, my chip is screwed Royally (by me, no less...LOL).
I got my XP1800+ the day after they were released by AMD, and way back when in Oct. '01, the unlocking methods were in their infancy for the Pallys.
It was rumored that the contacts for the L1's were buried just under the chip's substrate, and very lightly sanding the area around the L1's would uncover them, to allow unlocking.
It doesn't take much "sanding", even with 1500 grit wet/dry automotive type paper, to get down to copper.
Between the contacts.
Not much at all.
I did, get some of the multi's to work. Odd numbers only. Not one single even numbered, whether a round number, or a .5x setting, will boot.
My chip has run 1702 MHz since I got it. 11.5 x 148.
Using the Odd multi's (all I can work with);
9 x 166; 1494MHz. Underclocked.
9.5 x 166; 1577MHz. 44MHz over default, but a far shot from 1.7GHz.
11 x 166; 1826MHz. Outside the range the chip will run at.
If I had the 10"s or 12's to work with, by putting wire in the socket, I might be able to do something...
10.5 x 166; 1748MHz. This chip will run 1725, sometimes 1750 on a really good day. I might see this happen.
12.5 x 140(ish); 1750MHz. Again, right in the chip's "wheelhouse". This would also bring the bus closer to in spec than the 148 I run now... Not that it's ever been a problem at 148-150, but I like to keep it as close to in spec as possible.
B.
