Hi, the SS is with offset mode selected & that's why it's dropping like that. I also tried setting the Vcore manually but still the same results.I'm seeing a LOT of droop on the vCore. That's probably why Prime is dropping.
Hi Mandrake, Yes I kicked it back down to below 1600 & put it on auto with no joy there. My Cpu Nb is 1.25v.Have you tried dropping the memory to the next multiplier down? What is your Cpu NB Voltage set at?
I was thinking about the VRM also, as many people have said that the EVO board is a little lacking in that area. I've checked the memory at both 215 & 220 with memtest86 & all was good. Have dropped it back with no luck.With that much vcore you seem to have hit the limit of the chip as of what it can do with acceptable voltage. There is also a chance that your VRM starts to throttle or struggle under the load.
But you should try dropping the memory multiplier. Memory is quite stubborn when it comes to overclocking and you don't often see it doing much over rated speed unless it is quality OC memory.
Hi, Have the fan there. Looks like I might have reached that point. I have gone much higher & it holds for benches & whatever I need to do elsewhere. I'm putting together another computer on paper right now. It will be water cooled with a custom loop.dan, I know with my M5A99X evo board I hit a point where I just couldn't go any higher and run prime to find stability. You may have reached that point, you can try sticking a fan on the VRM heatsinks and see if cooling them down helps.
Dan
At 22x212 & the offset volts at the last yellow value (.1375v) Prime will drop a core after about 2 min. If I bump the offset up one value the first one in the red (.14375v) the computer hangs about 10 sec. into Prime.
1. Does that board have a setting where you can change the frequency of the VRMs? Stock is 300Mhz. Try 350 or 400.I do have that & will give it a try
3. So from 2.) above I expect you do n0t have enough Volts to the Cpu. I often find that jumping one small increment upwards only gets me a 'portion' of the keyed in Voltage. Often the actual cpu voltage supplied is rather a coarse approximation of what we key into the bios.Did not know that!
4. SO looking at your temps and knowing that my water cooled Vcore had to be increased by 0.03 when I moved from water to air...> that means in a general way your FX-8350 should perhaps get 1.48 + 0.03 = 1.51Volts for the cpu. You are n0t there yet voltage wise speaking in the general way that I am. Plus your cpu might take even more than mine to become stable. OR less but so far less has not proved accurate.Will give that a try
6. Okay looking at any loose ends besides the eVo and pRo boards don't have a robust enough VRM circuit, I don't see a bad ram situation and you have dropped the ram multiplier.
A.) I would make my ram voltage 1.55 if it is 1.50 ram.It is at 1.554v now
B.) I would make sure the CPU_NB was setting at about 1.25V with its' LLC set to HIGH if it has such in bios.Those both are there now
C.) I would also not have any issue with you dropping the cpu multiplier to 19x and raising the HT Ref Freq aka FSB to about 250 for <>4.8Ghz cpu speed. You need to make sure you change the ram speed downward and the CPU_NB downward and the HT Link Speed downward so that the 250 FSB does not push those into too high a range.I will give that a try
Good info here, Thanks RGone. I'll let you know how it goes.
Dan
Hi, hope it's not topped out, I didn't think about the Vdda I will give it a try.Im with RGone and ShrimpBrine I think you have probably reached the end of the line. One last thing you can try is give your CPU_VDDA a little bump, hope that's the right one I cant check as my system is still down. I am sure RGone can correct me if I am wrong. Bumping this on some lesser boards has helped with stability at the very upper end those of use using the top boards have not seen any improvement in stability if my memory is correct. There was a discussion a while back.
Dan just a heads up, I have played with the VDDC on my Asus boards and I haven't seen any proof that it helped stabilize it. Though, I never really did any true testing on it. Ssjwizard did find it helped on his Gigabyte board, here's the thread on it.Hi, hope it's not topped out, I didn't think about the Vdda I will give it a try.
Thanks Dan
Thanks for the info, I've started trying some of RGone's ideas but no luck so far. Haven't tried the VDDC yet.Dan just a heads up, I have played with the VDDC on my Asus boards and I haven't seen any proof that it helped stabilize it. Though, I never really did any true testing on it. Ssjwizard did find it helped on his Gigabyte board, here's the thread on it.
Thanks Dan
Dan
