- Apr 20, 2004
- JAX, Mississauna
Possible answers...
Possible answers:
1. No cooling to the VRMs and socket area when using AiO water cooling. There WAS overflow air cooling the VRMs and socket area, "if" a fan powered air cooler was mounted on top of the CPU for cooling cpu AiO and any water cooling will take away that cooling air from VRMs and Cpu socket area.
2. High current draw of 8 core processor is "over-taxing" the VRMs to supply enough power to the Cpu and thus are really running hot. This would mean that a fan blowing air over the VRM area is just about a MUST.
3. Most of us that really clock the pee out of these FX 8 core processors also have air circulation at the rear of the Cpu socket area. There have been pics of that shown by Johan45 and others.
Image concerning the air flow over VRMs.
Now I am going to be both very blunt and at the same time super honest. We are wasting a whole lot of time working with a motherboard that most of us already know is a huge hampering factor in any overclock of a power hungry 8 core FX processor. None of us that help 95% of the users in the AMD CPU and Motherboard Forum sections have ever recommended one of those entry level Asrock boards for anything like overclocking. Never have and never will. The boards are not ballsy enough to handle the power draw of an FX 8 core processor at anything much more than running HOW AMD designed that processor to be used and operated.
Run the cpu AS intended by AMD and it will do okay on that board. Start to push it even a little bit and then trouble starts as you are having. Simple as that and has been that way for 'everyone' of those boards that have come thru the AMD forum sections.
Now that leaves us right here: Do as suggested by the image above and then run it. That will be about it. Period. Whatever temp you get will be whatever temp you get and just live with it. All options are just about gone with that board as I best see it. I like to tinker with just about anything, but that even can become more or less useless after a bit of time without more positive results and then I drop the tinkering and use it or replace it. Sure enough.
RGone...
i am wondering why i can't get temps like your when u run a stress test..
Possible answers:
RGone...
