- May 1, 2003
- Seattle
crimedog said:aluminum tubes are better for ln2
That sounds dangerous, but fun! By the way, I bet a 2 inch base will help with cold bugged chips, put the temps where they need to be.Ross said:I think the phrase "grinding halt" is appropriate, literally LOL. Need to find a longer boring bar or it's going to have a 2" thick base.
Hey Maxi, can't you just weld a pipe over the boring bar that you have to extend it? Maybe rebar since it probably should be solid. It would be a whole lot cheaper to extend that one and replace it with a new one when done than to buy one with those specific dimensions
