Get a tracking # for that puppy...ie. is it definitely on the way? Lucky for you I've been too busy to bug youI did find one online however, should be here Monday
Nice!El<(')>Maxi said:Found a good supplier today, $205 for all this
2 2 3/4" copper 110, 1 3" 6061 blank, 1 3" tube & base for testing two piece unbrazed design with center pole.
Ross the tool should be here tomorrow, hang in there.
Thanks for the info on the thermocouple. No problem on the insulation and mounting...I'll get it on there if I have to hold it down by hand8MM base thickness. I'm cutting the container plate tomorrow and hopefully finishing this up. You'll need to get insultation & mouting bolts/backplate. I have a Fluke 51 II with K-Type, found it on e-bay a while back.
Just keep your tounge off that thingRoss said:Thanks for the info on the thermocouple. No problem on the insulation and mounting...I'll get it on there if I have to hold it down by hand
