ive been pondering this exact question for a while now...Ross said:For anyone who cares, no DEG in the socket and ZERO condensation anywhere other than the top of the tube and it was on there for a good 6 hours.
Many, many thanks to Maxi....this 6Ghz is for you
bazx said:hi joe i used Di-elect in the socket once never again stuff stick like sht to a blanket
still the best is vapo grease as it will go with a bit of contact spray
Ross said:Maxi, no condensation around the hold down at all...the insulation was fit tight top and bottom and the nylon, polyethylene or whatever those boards are made out of certainly don't seem to transfer heat far. It was cool afterwards, but not cold or freezing.
Eldonko said:Hey where does one get that plastic for hold down? I have to come up with some sorta hold down hardware.
El<(')>Maxi said:Maybe in a couple of weeks, are you thinking you need one?
Ross said:DI is great for benching, not a long term solution.
I'll let you know after I get the dual core on there this weekend, but I am thinking more like I want one than I need one ATMMaybe in a couple of weeks, are you thinking you need one?
There's just something fun about seeing 6GHz whether it benches higher than an AMD or notwould be fun to throw a new intel under one for a change of pace.
HA! Why do you think I put it on a DIY rack and not back in a $250 case?! Unfortunately for me, my local grocery store sells DI, is open 24/7 and is less than 2 miles away...makes it real hard on meSo addicting, I just can't stop...can't tell myself that dry ice doesn't grown on a tree either
