Only when you go into bios?Thanks! but before I overclock anything further, I have a problem.
I noticed sometimes when I go into bios, it freezes. What is causing this?
Leave rams at stock first, then try 1.4v for vcore...That should be fine for up to 4ghz.
I managed to OC to 4ghz. Using Zalman cpu heatsink fan.
Where do I go to overclock the rams? I have 4 gigs of 1333 rams.
Is it the DRAM configuration? Thanks.
The better chips can need as little as ~1.3-1.35v for 4 GHz, my 965 needing 1.344v, then there are others that need 1.55v...
Just need to set a voltage and up frequency a little at a time, or set frequency and up voltage until stable...
What is the current OC?
Yeah, it's crazy. I had a 965 with 1.425v VID in 2009/2010 that needed 1.55v for 3.9 GHz But CPU-NB did 3 GHzYep, there can be lots of variability in CPUs from the same model line in that sense.
