- May 22, 2011
- USA
Hey guys, helping someone build a rig and my question was will the Hyper 212 Plus since the EVO is sold out on the egg, (Egg prefer) has enough adequate air cooling to cool a FX-8350?
I didn't see anyone mention this about the Fx 8xxx cpu's, so I'll add it. They run hot, now I've never owned a 6 core Phenom. So I can't really say how much hotter, if any. Though the majority of us here that have them and start overclocking the Fx's, usually realize that they require big cooling, CM 212 need not apply here!
C_D that runs real applications on his FX's and does it for days on end, he has three-fan rads and 6 fans in push-pull to keep his FX-8350 within some form of heat limit when overclocked. Not sure what is used on his FX-6300 when he pushes it but I believe I remember it as having at least a three-fan radiator as well. Such is the reason why CM 212 coolers need not apply for keeping even a 6 core cool, WHEN the workload gets heavy. Gaming is one thing but work is that plus another half or so of heat to deal with. HOT is the story if pushed and worked.
If your friend is not going to overclock his/her FX8350 the CM212 cooler should be fine.
Thanks guys. There will be no overclocking what so ever. It's a budgeted build and have around $200-$250 maybe $300 max for a cpu + mobo combo. The FX seems to me to be the best buy for performance. We're looking to fit this all in in a NZXT 410 case with the stock fans included. It seemed for the price range it was the best one that felt had adequate intake cooling compared to the others.
Not too familiar with AMD components but if there's anything out there that is faster within budget limits, pls let us know. Thanks again.
Why pro? unless you need over 16gb ram that is a wasteLooking to purchase:
Windows 7 Pro 64-Bit
Seagate SSD (Looking to purchase these today because of the Black Deals before they disappear)
Crucial Ballistix 8GB (Looking to purchase these today because of the Black Deals before they disappear)
NZXT 410 Elite
CPU Cooler CM Plus or EVO (Which ever is available or affordable AIO)
CPU ??
MB ??
GPU ??
Any input or changes are greatly appreciated from you guys.
