- Apr 20, 2004
- JAX, Mississauna
Good...
...READ to READ Delay is in your bios ram settings. it is 4 now and would try 5. It will not hurt to go 6 but should not need to do so since changing 4 to 5 is likely enough.
That one setting by itself is what I use to run 2x4gig AND 2x4gig GSkill DDR3-1600 Ares and DDR3-1866 Ares together in my CHV-Z mobo. I have one brand new CHV-Z that has 4x4gig GSkill Ares 2400 in it running at DDR3-1866 set by "auto". So having that setting available is a HUGE bonus for mis-matched ram sets and 4 stick kits.
I would up ram voltage. I would up CPU-NB a little at a time. I have to run mine at 1.23V on one mobo and another board with another FX 8 core it takes 1.287V on CPU_NB. There is NO one size fits all. I make adjustments and then run P95 Blend mode for at least 20 mins and view HWMonitor Free for Max Temps/Volts.
So set READ to READ Delay to 5. Adjust ram voltage upward. 1.6V is not harmful. But I would try 1.55V first and with CPU_NB at 1.25V. Do at least 20 mins of P95 Blend. I would try this with 21x multiplier on cpu and that would be 4.2Ghz BUT it will have ALL 8 cpu cores on at one time at that same overclocked speed. That is NOT how AMD specs it and much more power hungry and HOT. So am not suggesting higher than 4.2Ghz to begin with. I would set CPU voltage to 1.35V for first testing, but may or may not take a little more or get by with a little less. These later FX 8 cores often can get by with less cpu voltage than 18 mos ago.
Think that is what I would do first and then give us the captures of CPU-z > CPU Tab > Memory Tab > SPD Tab and finally a capture of HWMonitor Free while it has been running logging Min/Max Temps/Volts during at least 20 mins of P95 Blend.
Luck man.
RGone...
Luck man.
RGone...
