- Apr 9, 2015
- Uruguay
Hello mates. I didn't feel like this bad for some long time
My configuration is in the signature. The only change, I installed a FX9590.
The PC seems to start, it beeps, then makes nothing, doesn't shows BIOS, anything.
I dont know what else to tell.
My PC was running excelent with my fx8350. But i wanted to try a change.
Before I shut down last time i forgot to let the Bios settings y default. I changed de CPU, I started the PC and nothing.
I thought, OK y erase the BIOS Config, cmos, and it would start. i Cleared CMOS. But anyway, didnt work.
I think my PSU is enough.
Can you help me in this situation??
Regards
Regards
