I'll go play with d BIOS and let u know. Just hang on for a moment. I'll upload my CPU-Z current report now.
CPU-Z TXT Report
Binaries
CPU-Z version 1.58
Processors
Number of processors 1
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name AMD Sempron 140
Codename Sargas
Specification AMD Sempron(tm) 140 Processor
Package Socket AM3 (938)
CPUID F.6.2
Extended CPUID 10.6
Brand ID 9
Core Stepping DA-C2
Technology 45 nm
TDP Limit 41 Watts
Core Speed 2906.5 MHz
Multiplier x FSB 13.5 x 215.3 MHz
HT Link speed 1076.5 MHz
Stock frequency 2700 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 1024 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
FID range 4.0x - 13.5x
Max VID 1.350 V
P-State FID 0xB - VID 0x10 - IDD 30 (13.50x - 1.350 V)
P-State FID 0x3 - VID 0x18 - IDD 25 (9.50x - 1.250 V)
P-State FID 0x10E - VID 0x20 - IDD 24 (7.50x - 1.150 V)
P-State FID 0x100 - VID 0x26 - IDD 14 (4.00x - 1.075 V)
Package Type 0x1
Model 40
String 1 0x2
String 2 0xA
Page 0x0
CmpCap 1
ApicIdCoreSize 4
TDC Limit 30 Amps
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02004008h
Max CPUID level 00000005h
Max CPUID ext. level 8000001Bh
Cache descriptor Level 1, I, 64 KB, 1 thread(s)
Cache descriptor Level 1, D, 64 KB, 1 thread(s)
Cache descriptor Level 2, U, 1 MB, 1 thread(s)
CPUID
0x00000000 0x00000005 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00100F62 0x00010800 0x00802009 0x078BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000000
0x80000000 0x8000001B 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00100F62 0x1000128A 0x000037FD 0xEFD3FBFF
0x80000002 0x20444D41 0x706D6553 0x286E6F72 0x20296D74
0x80000003 0x20303431 0x636F7250 0x6F737365 0x00000072
0x80000004 0x00000000 0x00000000 0x00000000 0x00000000
0x80000005 0xFF30FF10 0xFF30FF20 0x40020140 0x40020140
0x80000006 0x20800000 0x42004200 0x04008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x000001F9
0x80000008 0x00003030 0x00000000 0x00002000 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000040 0x00000000 0x0000000F
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF0300000 0x60100000 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x0000001F 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000008
MSR 0xC0010061 0x00000000 0x00000030
MSR 0xC0010062 0x00000000 0x00000000
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010064 0x8000001E 0x2000200B
MSR 0xC0010065 0x800001F7 0x30003003
MSR 0xC0010066 0x800001EB 0x4000404E
MSR 0xC0010067 0x80000187 0x4C004C40
MSR 0xC0010068 0x00000187 0x4C004C40
MSR 0xC0010071 0x30B60083 0x2000200B
MSR 0xC0010015 0x00000000 0x01000010
MSR 0xC001001F 0x42584000 0x00000008
MSR 0xC0010058 0x00000000 0xFC000015
MSR 0xC0010004 0x00001AFB 0xF06E4334
MSR 0xC0010070 0x00000000 0x2000200B
Chipset
Northbridge NVIDIA GeForce 7025 rev. A3
Southbridge NVIDIA nForce 630a rev. A2
Memory Type DDR2
Memory Size 2048 MBytes
Channels Single
Memory Frequency 287.1 MHz (3:4)
CAS# latency (CL) 4.0
RAS# to CAS# delay (tRCD) 4
RAS# Precharge (tRP) 4
Cycle Time (tRAS) 12
Bank Cycle Time (tRC) 16
Command Rate (CR) 2T
Uncore Frequency 1937.6 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Kingmax Semiconductor (7F7F7F2500000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number KLDE88F-B8KU5
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-9-12 @ 200 MHz
JEDEC #2 4.0-4-4-12-16 @ 266 MHz
JEDEC #3 5.0-5-5-18-23 @ 400 MHz
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00
10 0C 08 38 01 02 00 03 3D 50 50 60 32 1E 32 2D 01
20 17 25 05 12 3C 1E 1E 00 00 39 7F 80 14 1E 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 C3
40 7F 7F 7F 25 00 00 00 00 41 4B 4C 44 45 38 38 46
50 2D 42 38 4B 55 35 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Monitoring
Mainboard Model N68-S (0x0000013C - 0x00029BB0)
LPCIO
LPCIO Vendor Winbond
LPCIO Model W83627DHG-P
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xB0
LPCIO Revision ID 0x73
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 B0 73 FF 00 0C 00 00 FF 50 00 00 00 02 01 00 FF
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Winbond W83627DHG
Voltage 0 1.34 Volts [0xA8] (CPU VCORE)
Voltage 1 0.29 Volts [0x24] (VIN1)
Voltage 2 3.36 Volts [0xD2] (+3.3V)
Voltage 3 5.04 Volts [0xD2] (+5V)
Voltage 4 11.77 Volts [0xD3] (+12V)
Voltage 5 1.69 Volts [0xD3] (VIN5)
Voltage 6 1.83 Volts [0xE5] (VIN6)
Temperature 0 36°C (96°F) [0x24] (SYSTIN)
Temperature 1 42°C (106°F) [0x53] (CPUTIN)
Temperature 2 32°C (88°F) [0x3F] (AUXTIN)
Fan 1 3309 RPM [0x33] (CPUFANIN0)
Hardware registers
bank 0
00 04 FF 04 FF 01 00 00 00 01 01 01 01 3C 3C 0A 0A
10 04 FF 10 00 00 01 01 3C 43 07 00 00 2A FF FF C8
20 A8 25 D2 D2 D3 D3 E5 24 FF 33 FF DA 00 55 C6 E9
30 D1 51 51 4F 2C 73 47 4D 1B 99 47 80 60 13 E2 FF
40 03 5A 1F FF FF 00 3F F5 2D 00 00 C4 10 95 00 A3
50 FF FF 00 FF FF FF 00 80 C1 7F FF FF 19 A0 00 05
60 04 7F 40 00 01 01 3C FF 01 FF 01 FF FF FF FF 00
70 00 00 00 00 00 0E 7F 7F 7F 7F 7F 7F 00 24 FF FF
80 04 FF 04 FF 01 00 00 00 01 01 01 01 3C 3C 0A 0A
90 04 FF 10 00 00 01 01 3C 43 07 00 00 2A FF FF C8
A0 A8 25 D2 D2 D3 D3 E5 24 FF 33 FF DA 00 55 C6 E9
B0 D1 51 51 4F 2C 73 47 4D 1B 99 47 80 60 13 E2 FF
C0 03 00 10 FF FF 00 3F F5 2D 00 00 C4 10 95 00 A3
D0 FF FF 00 FF FF FF 00 80 C1 7F FF FF 19 A0 00 05
E0 04 7F 40 00 01 01 3C FF 01 FF 01 FF FF FF FF 00
F0 00 00 00 00 00 0E 7F 7F 7F 7F 7F 7F 00 24 FF FF
bank 1
50 29 80 00 4B 00 50 05 F8 00 00 00 00 00 00 0E FF
bank 2
50 1F 80 00 4B 00 50 1E 02 FF FF FF FF FF FF FF FF
bank 3
50 06 00 07 06 00 06 04 06 03 00 00 10 7F 0B 00 00
bank 4
50 3B 13 FF 00 00 00 00 0E 69 4A 1D BB 09 60 20 7F
PCI Devices
Description RAM Memory Controller
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E2
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1849
Subsystem ID 0x03E2
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class HyperTransport
Caps offset 0x44
Caps revision 1.03
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 1000 MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200 MHz
PCI capability
Caps offset 0xDC
Interface type MSI Mapping
PCI registers
00 DE 10 E2 03 06 00 B0 00 A1 00 00 05 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 E2 03
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00
40 49 18 E2 03 08 DC 20 02 20 00 11 11 D0 00 00 00
50 23 06 7F 00 03 00 00 00 00 00 03 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 00
70 44 44 44 00 D0 09 00 00 11 00 00 00 11 11 88 00
80 23 99 88 00 FA 00 64 0D 03 00 00 00 7F 00 00 00
90 7E 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 01 01 01 01 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 01 A8
E0 00 00 E0 FE 00 00 00 00 07 00 00 00 20 10 00 00
F0 F0 FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E1
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x00000900
Subvendor ID 0x1849
Subsystem ID 0x03E1
Int. Line 0xFF
Int. Pin 0x00
PCI registers
00 DE 10 E1 03 0F 00 A0 00 A2 00 01 06 00 00 80 00
10 01 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 E1 03
30 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00
40 49 18 E1 03 00 00 D0 FE FA 3E FF 00 FA 3E FF 00
50 FA 3E FF 00 00 5A 62 02 00 00 00 05 1F 00 00 00
70 10 00 FF FF C5 80 00 00 00 00 45 19 00 00 00 00
80 09 10 00 80 08 20 D0 00 00 00 40 01 FF 00 00 00
90 FF 7F 00 00 FF FF 3F 3F 21 65 08 74 B9 0C 00 D0
A0 01 00 00 81 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 80 02 FF 02 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 FE FD 03 00 A0
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03EB
Revision ID 0xA2
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000EC00
Address 4 (port) 0x00000600
Address 5 (port) 0x00000700
Subvendor ID 0x1849
Subsystem ID 0x03EB
Int. Line 0x0B
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 EB 03 01 00 B0 00 A2 00 05 0C 00 00 80 00
10 01 EC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 06 00 00 01 07 00 00 00 00 00 00 49 18 EB 03
30 00 00 00 00 44 00 00 00 00 00 00 00 0B 01 00 00
40 49 18 EB 03 01 00 02 C0 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 01 05 00 00 01 08 00 00 01 0D 00 00 00 00 00 00
70 00 00 00 00 00 00 C8 FE 00 00 FE FE 01 11 00 00
80 00 10 FE FE 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 D4 30 80 01 01 00 00 00 00 00 00 00 00 00 00 00
D0 40 00 40 01 10 00 00 00 05 00 00 00 00 00 00 00
E0 88 10 04 00 04 40 00 07 80 46 00 20 41 44 44 11
F0 02 FF 1E BF 01 00 00 80 10 00 00 00 00 00 00 00
Location bus 0 (0x00), device 1 (0x01), function 2 (0x02)
Common header
Vendor ID 0x10DE
Model ID 0x03F5
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1849
Subsystem ID 0x03EB
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 F5 03 00 04 A0 00 A2 00 00 05 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 EB 03
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 49 18 F5 03 00 00 00 00 10 02 80 10 10 00 10 10
50 10 10 10 10 00 00 00 00 00 00 00 00 10 42 00 00
60 0B 00 00 00 C0 1C 52 06 21 00 10 0A 00 00 63 00
70 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 40 00 00 00 00 00 A0 18 00 00
90 00 00 00 00 00 00 00 12 20 81 04 00 00 00 00 00
A0 00 14 00 06 00 00 00 00 00 00 00 00 01 00 00 00
B0 00 00 00 00 42 80 30 04 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB Controller (OHCI)
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F1
Revision ID 0xA3
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFBFFF000
Subvendor ID 0x1849
Subsystem ID 0x03F1
Int. Line 0x14
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 F1 03 06 00 B0 00 A3 10 03 0C 00 00 80 00
10 00 F0 FF FB 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 F1 03
30 00 00 00 00 44 00 00 00 00 00 00 00 14 01 03 01
40 49 18 F1 03 01 00 02 FE 00 00 00 00 00 00 00 00
50 80 00 00 00 1D 47 40 00 10 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03F2
Revision ID 0xA3
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFBFFEC00
Subvendor ID 0x1849
Subsystem ID 0x03F2
Int. Line 0x17
Int. Pin 0x02
PCI capability
Caps class Debug Port
Caps offset 0x44
PCI capability
Caps offset 0x80
Caps version 1.1
PCI registers
00 DE 10 F2 03 06 00 B0 00 A3 20 03 0C 00 00 80 00
10 00 EC FF FB 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 F2 03
30 00 00 00 00 44 00 00 00 00 00 00 00 17 02 03 01
40 49 18 F2 03 0A 80 98 20 00 00 00 00 00 00 00 00
60 20 20 01 00 00 60 18 85 C3 13 0F 01 00 00 00 00
70 00 00 08 00 00 10 20 80 89 3D B6 22 77 25 14 00
80 01 00 02 FE 00 80 00 00 00 00 00 00 15 16 00 00
90 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00
B0 00 11 22 33 44 00 00 00 FF 01 00 00 00 00 00 00
C0 10 10 2D 0D 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F3
Revision ID 0xA1
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Subsystem Vendor
Caps offset 0xB8
SubVendor ID 0x1849
SubSystem ID 0x03F3
PCI capability
Caps offset 0x8C
PCI registers
00 DE 10 F3 03 07 04 B0 00 A1 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 20 F0 00 80 22
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 B8 00 00 00 00 00 00 00 00 00 02 02
40 00 00 73 07 01 00 02 00 07 00 00 00 00 00 48 00
50 00 00 00 00 00 00 00 00 FF 1F FF 1F 00 00 00 00
80 00 06 00 00 00 00 00 00 00 00 00 00 08 00 01 A8
90 00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
A0 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 FF FF 00 00 0D 8C 00 00 49 18 F3 03
C0 49 18 F3 03 03 00 00 00 00 00 00 00 00 00 00 00
Description Multimedia device
Location bus 0 (0x00), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F0
Revision ID 0xA2
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFBFF8000
Subvendor ID 0x1849
Subsystem ID 0x0397
Int. Line 0x16
Int. Pin 0x02
PCI capability
Caps offset 0x44
Caps version 1.1
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x50
PCI capability
Caps offset 0x6C
PCI registers
00 DE 10 F0 03 06 00 B0 00 A2 00 03 04 00 00 80 00
10 00 80 FF FB 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 97 03
30 00 00 00 00 44 00 00 00 00 00 00 00 16 02 02 05
40 49 18 97 03 01 50 02 C0 00 00 00 00 01 01 0F 00
50 05 6C 80 01 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 0F 00 00 00 08 00 03 A8
F0 00 00 00 00 00 00 00 47 00 29 00 00 00 00 00 00
Description IDE Controller
Location bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F6
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000E480
Address 1 (port) 0x0000E400
Address 2 (port) 0x0000E080
Address 3 (port) 0x0000E000
Address 4 (port) 0x0000DC00
Address 5 (memory) 0xFBFFD000
Subvendor ID 0x1849
Subsystem ID 0x03F6
Int. Line 0x14
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI capability
Caps offset 0xB0
PCI capability
Caps offset 0xCC
PCI registers
00 DE 10 F6 03 07 00 B0 00 A2 85 01 01 00 00 80 00
10 81 E4 00 00 01 E4 00 00 81 E0 00 00 01 E0 00 00
20 01 DC 00 00 00 D0 FF FB 00 00 00 00 49 18 F6 03
40 49 18 F6 03 01 B0 02 00 00 00 00 00 00 00 00 00
50 2F 68 08 00 00 00 00 00 00 20 00 20 44 20 00 20
60 00 00 00 C7 41 0C 00 00 00 0F 06 42 00 00 00 00
70 2C 78 C4 40 01 10 00 00 01 10 00 00 20 00 20 01
80 00 00 00 C0 00 20 DE 4C 00 00 94 98 F6 FF BF B7
90 00 00 84 3D 00 00 00 00 06 00 06 10 F6 03 01 01
A0 08 00 00 10 00 00 00 00 00 00 00 00 33 31 00 02
B0 05 CC 84 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 0A 00 0A 00 08 00 03 A8
D0 08 00 00 77 00 08 03 00 08 00 00 44 00 08 00 00
E0 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
Location bus 0 (0x00), device 8 (0x08), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03F6
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000D880
Address 1 (port) 0x0000D800
Address 2 (port) 0x0000D480
Address 3 (port) 0x0000D400
Address 4 (port) 0x0000D080
Address 5 (memory) 0xFBFFC000
Subvendor ID 0x1849
Subsystem ID 0x03F6
Int. Line 0x05
Int. Pin 0x02
PCI capability
Caps offset 0x44
Caps version 1.1
PCI capability
Caps offset 0xB0
PCI capability
Caps offset 0xCC
PCI registers
00 DE 10 F6 03 00 04 B0 00 A2 85 01 01 00 00 80 00
10 81 D8 00 00 01 D8 00 00 81 D4 00 00 01 D4 00 00
20 81 D0 00 00 00 C0 FF FB 00 00 00 00 49 18 F6 03
30 00 00 00 00 44 00 00 00 00 00 00 00 05 02 03 01
50 0F 68 08 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 41 0C 00 00 00 0F 06 42 00 00 00 00
70 2C 78 C4 40 01 10 00 00 01 10 00 00 20 00 20 81
80 00 00 00 00 BE FF DB 4E 00 00 7D 2B BA D5 BF F6
90 00 00 B6 2F 00 00 00 00 06 00 06 10 F6 03 01 01
A0 08 00 00 00 00 00 00 00 00 00 00 00 33 31 00 02
C0 00 00 00 00 00 00 00 00 0A 00 0A 00 08 00 02 A8
D0 08 00 00 44 00 08 08 00 08 00 00 44 00 08 08 00
Location bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E8
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1849
SubSystem ID 0x03E8
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps class PCI Express
Caps offset 0x80
Device type Root Port of PCI-E Root Complex
Port 0
Version 1.0
Physical slot #0
Presence detect no
Link width 16x (max 16x)
Extended capabilities
Caps class Virtual Channel
Caps offset 0x100
PCI registers
00 DE 10 E8 03 04 04 10 00 A2 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 F1 01 00 00
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 02 00
40 0D 48 00 00 49 18 E8 03 01 50 02 F8 00 00 00 00
50 05 60 93 00 00 00 E0 FE 00 00 00 00 A2 40 00 00
60 08 80 01 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
80 10 00 41 01 01 80 00 00 10 28 00 00 01 3D 11 00
90 00 00 01 11 80 25 08 00 C0 01 00 00 00 00 00 00
100 02 00 01 00 00 00 00 00 00 00 00 00 02 00 00 00
110 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
120 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E9
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1849
SubSystem ID 0x03E9
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x80
Port 1
Version 1.0
Physical slot #0
Presence detect no
Link width 1x (max 1x)
Caps offset 0x100
PCI registers
00 DE 10 E9 03 04 04 10 00 A2 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 00 F1 01 00 00
40 0D 48 00 00 49 18 E9 03 01 50 02 F8 00 00 00 00
50 05 60 93 00 00 00 E0 FE 00 00 00 00 92 40 00 00
80 10 00 41 01 01 80 00 00 10 28 00 00 11 3C 11 01
90 00 00 11 10 00 05 10 00 C0 01 00 00 00 00 00 00
Location bus 0 (0x00), device 12 (0x0C), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E9
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1849
SubSystem ID 0x03E9
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x80
Port 2
Version 1.0
Physical slot #0
Presence detect no
Caps offset 0x100
PCI registers
10 00 00 00 00 00 00 00 00 00 04 04 00 F1 01 00 00
50 05 60 93 00 00 00 E0 FE 00 00 00 00 82 40 00 00
80 10 00 41 01 01 80 00 00 10 28 00 00 11 3C 11 02
90 00 00 11 10 00 05 18 00 C0 01 00 00 00 00 00 00
Description VGA Controller
Location bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03D6
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFA000000
Address 1 (memory) 0xE0000000
Address 3 (memory) 0xF9000000
Subvendor ID 0x1849
Subsystem ID 0x03D6
Int. Line 0x15
Int. Pin 0x01
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI registers
00 DE 10 D6 03 07 00 B0 00 A2 00 00 03 00 00 00 00
10 00 00 00 FA 0C 00 00 E0 00 00 00 00 04 00 00 F9
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 D6 03
30 00 00 00 00 48 00 00 00 00 00 00 00 15 01 00 00
40 49 18 D6 03 00 00 00 03 01 50 02 00 00 00 00 00
50 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
60 01 00 00 00 1C 04 04 00 00 00 00 00 00 00 00 00
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 00 00 E0 00 00 00 00 10 00 00 00 00 FF FF FF FF
Description Host Bridge
Location bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1200
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x80
Caps revision 3.00
Interface type Host/Secondary
Device number 0
PCI registers
00 22 10 00 12 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00
50 01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00
60 00 00 00 00 E0 00 00 00 0F AC 4E 00 00 F8 00 00
80 08 00 01 21 20 20 11 11 60 06 F5 8F 13 00 00 00
90 92 02 85 84 00 00 00 00 07 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1201
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 01 12 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 7F 00 00 00 00 00 00 00 00 00
80 03 00 FC 00 80 FF FD 00 03 00 80 00 00 FF FB 00
90 03 00 FE 00 00 0B FE 00 00 00 00 00 00 00 00 00
B0 03 0A 00 00 00 0B 00 00 00 00 00 00 00 00 00 00
C0 13 10 00 00 00 F0 FF 00 00 00 00 00 00 00 00 00
E0 03 00 00 07 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1202
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 02 12 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00
60 E0 3E 78 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 06 00 48 11 00 00 00 00
80 05 00 00 00 00 00 00 00 13 91 15 5D 34 02 22 00
90 10 04 01 00 09 80 58 3F 07 03 00 80 00 00 00 00
A0 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 64 F9 ED 32 23 00 00 00 EB E8 37 96 BF DA 8B F1
D0 FF DF FB BF FD FB EF BF BF F7 AF 3F FA 97 7F ED
E0 7F FD FD 03 FE FF 7F 7D BC E9 6F F7 FF E7 EF 87
Location bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1203
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Secure Device
Caps offset 0xF0
PCI registers
00 22 10 03 12 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00
40 FF FF FF 3F 5C 00 B0 4A 00 00 00 00 00 00 00 00
60 00 00 00 00 05 77 24 34 00 00 00 30 51 80 01 60
70 51 11 22 61 01 01 18 91 14 0C 20 00 0F 08 07 00
80 81 07 00 E6 E6 41 E6 80 08 00 00 00 00 40 58 42
90 00 00 00 00 3F 50 00 00 F0 D7 FF FE 00 00 00 00
A0 00 09 08 90 80 18 08 20 00 00 00 00 00 00 00 00
D0 00 00 00 00 25 0F 81 C8 16 0F 26 03 26 53 20 00
E0 00 00 00 00 30 0A 00 1F 79 0F 07 00 00 00 00 00
F0 0F 00 10 00 00 00 00 00 00 00 00 00 62 0F 10 00
Location bus 0 (0x00), device 24 (0x18), function 4 (0x04)
Common header
Vendor ID 0x1022
Model ID 0x1204
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 04 12 00 00 00 00 00 00 00 06 00 00 80 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version P2.10
date 04/21/2010
DMI System Information
manufacturer To Be Filled By O.E.M.
product To Be Filled By O.E.M.
version To Be Filled By O.E.M.
serial To Be Filled By O.E.M.
UUID {03000200-0400-0500-0006-000700080009}
DMI Baseboard
vendor ASRock
model N68-S
revision unknown
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Processor
manufacturer AMD
model AMD Sempron(tm) 140 Processor
clock speed 2906.0 MHz
FSB speed 200.0 MHz
multiplier 14.5x
DMI Memory Controller
correction 64-bit ECC
Max module size 2048 MBytes
DMI Memory Module
designation DIMM0
size 2048 MBytes (double bank)
DMI Memory Module
designation DIMM1
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCIE1
type A5
populated no
DMI Extension Slot
designation PCIE2
type A5
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 8192 MBytes
max# of devices 2
DMI Memory Device
designation DIMM0
format DIMM
type unknown
total width 64 bits
data width 72 bits
size 2048 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type unknown
data width 64 bits
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce 7025 / NVIDIA nForce 630a
Revision A2
Memory size 256 MB
PCI device bus 0 (0x0), device 13 (0xD), function 0 (0x0)
Vendor ID 0x10DE (0x1849)
Model ID 0x03D6 (0x03D6)
Performance Level 0
Core clock 425.0 MHz
Memory clock 532.0 MHz
Software
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
DirectX Version 11.0
ACPI
ACPI Tree
_GPE
_L01
_L0B
_L10
_L03
_L09
_L0D
_L05
_L00
_L15
_L11
_PR_
P001
P002
P003
P004
P005
P006
CPU1
CPU2
CPU3
CPU4
CPU5
CPU6
_SB_
PR00
AR00
PR10
AR10
PR11
AR11
PR12
AR12
PR01
AR01
PRSA
PRSB
PRSC
PRSD
RSEA
RSEB
RSEC
RSED
RSMB
RSB2
RSMU
RSA1
RSA0
RSB0
RSAC
RSZA
RSCI
RSC9
RSTA
RSIR
RSII
PCI0
_HID
_ADR
_BBN
_UID
_PRT
NPTS
NWAK
SBRG
_ADR
SPTS
SWAK
SMIE
PS1S
PS1E
SXCT
S1CT
S3CT
S4CT
S5CT
PIC_
_HID
_CRS
DMAD
_HID
_CRS
TMR_
_HID
_CRS
RTC0
_HID
_CRS
SPKR
_HID
_CRS
COPR
_HID
_CRS
FDC_
_HID
_FDE
_STA
_DIS
_CRS
_SRS
_PRS
LPTE
_HID
_STA
_DIS
_CRS
_SRS
_PRS
LPPR
EPPR
RMSC
_HID
_UID
CRS_
_CRS
HPET
_HID
_UID
CRS_
_STA
_CRS
HPTE
NVID
LPDC
S3F8
S2F8
S2E8
S3E8
M300
M330
FDC0
P378
P278
P3BC
G200
G208
RRIO
RDMA
OMSC
_HID
_UID
CRS_
CRS1
_CRS
PS2K
_HID
_CID
_STA
_CRS
_PRW
_PSW
PS2M
_HID
_CID
_STA
M2R0
M2R1
_CRS
_PRW
_PSW
UAR1
_UID
_HID
_STA
_DIS
_CRS
_SRS
_PRS
CMPR
_PRW
SIOR
_HID
_UID
CRS_
_CRS
DCAT
ENFG
EXFG
LPTM
UHID
SIOK
SLED
KBFG
MSFG
U1FG
U2FG
SIOS
SIOW
SIOH
IOID
INDX
DATA
LDN_
FDCP
LPTP
URAP
URBP
ACTR
IOAH
IOAL
IOH2
IOL2
INTR
DMCH
CRE0
CRE1
CRE2
CRE3
CRE4
CRE5
CRE6
OPT0
OPT1
OPT2
OPT3
OPT4
OPT5
OPT6
CGLD
DSTA
DCNT
CRS1
IRQM
DMAM
IO11
IO12
LEN1
CRS2
IRQE
DMAE
IO21
IO22
LEN2
IO31
IO32
LEN3
DCRS
DSRS
PIMC
_S3D
_S1D
NATA
NVRB
_HID
_STA
_CRS
PCIE
_HID
_UID
CRS_
_CRS
NSMB
_ADR
_PRW
USB0
_ADR
_S1D
_S3D
_PRW
USB2
_ADR
_S1D
_S3D
_PRW
NMAC
_ADR
_PRW
IDE0
_ADR
PTS0
SID0
SID1
SID2
SID3
SID4
SID5
IRQM
IR0M
REGF
_REG
A090
ID20
IDTS
IDTP
ID22
UMSS
UMSP
TIM0
TMD0
PIO0
DMA0
PIO1
DMA1
CHNF
CFG2
SSPT
SMPT
PSPT
PMPT
SSAS
SMAS
PSAS
PMAS
SDDR
SDDA
PDDR
PDDA
SSUT
SSUE
SMUT
SMUE
PSUT
PSUE
PMUT
PMUE
GMPT
GMUE
GMUT
GSPT
GSUE
GSUT
CHN0
_ADR
_GTM
_STM
DRV0
_ADR
_GTF
DRV1
_ADR
_GTF
CHN1
_ADR
_GTM
_STM
DRV0
_ADR
_GTF
DRV1
_ADR
_GTF
DRMP
GTM_
STM_
AT01
AT02
AT03
AT04
ATA0
ATA1
ATA2
ATA3
ATAB
CMDC
GTFB
GTF_
RATA
ATA0
_ADR
SARG
UMS1
EMS1
UMS0
EMS0
UMP1
EMP1
UMP0
EMP0
TIM0
PRI0
_ADR
SPTM
DMA0
_GTM
_STM
MAST
_ADR
_GTF
SEC0
_ADR
SSTM
DMA0
_GTM
_STM
MAST
_ADR
_GTF
DRMP
ATA1
_ADR
SARG
UMS1
EMS1
UMS0
EMS0
UMP1
EMP1
UMP0
EMP0
TIM0
PRI0
_ADR
SPTM
DMA0
_GTM
_STM
MAST
_ADR
_GTF
SEC0
_ADR
SSTM
DMA0
_GTM
_STM
MAST
_ADR
_GTF
DRMP
P0P1
_ADR
_PRW
_PRT
HDAC
_ADR
_PRW
SGPU
_ADR
BR10
_ADR
_PRW
_PRT
PES1
_ADR
BR11
_ADR
_PRW
_PRT
PES2
_ADR
BR12
_ADR
_PRW
_PRT
SUPP
CTRL
AOSC
CRS_
MIN5
MAX5
LEN5
MIN6
MAX6
LEN6
_CRS
BN00
SMIP
SLPS
AWY_
_HID
_STA
SMOD
RMEM
_HID
_UID
CRS_
_CRS
PWRB
_HID
_UID
_STA
BUFA
ICRS
LSTA
LPRS
LCRS
LCRO
LSRS
LSRO
LNKA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKB
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKC
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKD
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNEA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNEB
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNEC
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNED
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LUB0
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LUB2
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LMAC
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LAZA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LACI
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LMC9
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LSMB
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LPMU
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LSA0
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LSA1
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LATA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
XCPD
XNPT
XCAP
XDCP
XDCT
XDST
XLCP
XLCT
XLST
XSCP
XSCT
XSST
XRCT
MUTE
RBPE
RWPE
RDPE
WBPE
WWPE
WDPE
RWDP
RPME
_SI_
_TZ_
_REV
_OS_
_OSI
_GL_
DP80
DP90
SPIO
IOSB
IOSL
IOHB
IOHL
SSMI
SSEP
SSEN
APIC
SHPB
SHPL
PMBS
PMLN
SCBS
SCLN
ACBS
ACLN
IGPB
IGLN
ACA4
SCIO
SCTL
EXTS
SGPS
SGPM
SGPL
SNAS
SNAM
SNAL
AWAY
PCIB
PCIL
WKTP
SL2P
BIOS
SS1_
SS2_
SS3_
SS4_
IOST
TOPM
ROMS
MG1B
MG1L
MG2B
MG2L
DMAX
HPTA
CPB0
CPB1
CPB2
CPB3
ASSB
AOTB
AAXB
SMIF
DTSE
DTS1
DTS2
MPEN
OSTP
RRIO
RDMA
PICM
_PIC
OSVR
OSFL
MCTH
PRWP
GPRW
WAKP
DEB0
DBG8
DEB1
DBG9
OSYS
SCPP
FZTF
PIRA
PIRB
PIRC
PIRD
PREA
PREB
PREC
PRED
PIRM
PIU2
PMUD
SIID
PIID
PIU0
PIU1
PILN
PAZA
PAUI
PIMO
PR0E
NPTS
NWAK
W2KW
WOTB
WSSB
WAXB
_PTS
_WAK
_S0_
_S1_
_S4_
_S5_
PTS_
WAK_
