- Jun 28, 2012
Those are the boards I was thinking about... The disappointment was that higher speeds weren't available out of the box as it were, with the reported limits depending on number and type of module populated. Every OC Intel DDR4 system I have has run to around 3000 easy, with a module it likes at the least. If high end boards go to 4000+ that lower boards can't, fair enough. But lower AM4 boards here just seem a bit too low. On the Intel side, basically I would expect 3200+ out of a Prime X370 board or equivalent position/price without having to go to the expense of the Crosshair.
I recall quite a few speed increases along the way with Socket 1151... It used to be a golden pairing to run DDR4-3600+ and now DDR4-3866 is a set-and-forget.
BIOS maturity goes a long way for DRAM capabilities and compatibility.
