- Jan 12, 2012
Nice tidy post there Mr. Clean Manny.
RGone...
Thanks Dakz, that's why we keep coming here for the success stories such as yours. I see you still hang around the forums which is good, we can always use another to jump in and help out.
DAKz said:Well for no real reason I did bump it up to 4.74 and seems to be the same, I did this by upping the multi only and its stable and about the same temp, so another step in the process. Was wondering after reading dome of the other threads if the 8350 makes that big a difference seem like several are running over the 5ghz mark. Thoughts?
Johan45 said:Mr. Rgone did some extensive testing about the 8350 and performance at higher clocks. http://www.overclockers.com/forums/s...light=flatline
Personally I don't see the benefit in day to dayy computering to running this chip at that speed. I only run speeds like that for benchmarks, I've had it up to 5.469 for a quick run of Superpi but it was no where near stable. The voltages it need to remain stable at speeds like that would just wear down your CPU.
