- Aug 19, 2012
I would look to try keep the Temps under 85c when testing with P95 on your hottest core, as you can see. When Web Browsing and Games the Temps are lower overall.
You could reach about 4.7ghz depending on your cooling and how it stands up to the heat!! But 4.4 or 4.6 is a good everyday OC and looking at your Voltage your doing just great so far. Sometimes that little extra 100hz is not really worth all the effort, yep 4.6 fully stable would be really good!!
Well done AJ.
Well done AJ.
