Im still not sure how I have left out the molex labled "led strip" but the strip still lights up. Just not in the way I seen in seen on youtube.
the lead coming off the led light controller marked led strip is for you to plug in an after market light strip. to power itthats the one marked 12v there are also like 6 2 pin wires that allow you to control the lights on your fans if they are controllable in this way. I have the enthoo primo case and luckily for me I have bitfenix fans which have a secondary 2 pin wire for controlling the leds.
LLC adjustment is good almost only while OC. If you want to set higher clock then ( at least for me ) best on ASUS boards is high LLC. High LLC is usually keeping about as high voltage under load as you set in BIOS. Extreme is usually bumping it above values that you set manually. It's of course safe but not really required for light OC.
Best is to OC using CPU ratio as higher bclk usually needs higher voltages and is harder to stabilize while effective performance is about the same.
CPU strap is needed only if you set 125+ or 167+ bclk but I recommend to try max clock at 100bclk and higher CPU ratio before you start to play with straps and higher bclk.
