- Dec 10, 2011
- Cádiz (Spain)
You only need the basics: CPU, any video output (iGPU and any display will do), RAM, motherboard, PSU and keyboard, no need for storage devices or other HID.
Remove the lithium battery for a minute or two and that should reset everything.
Stupid question..... you do have the 8-pin power lead connected to the motherboard correct?
Just use windows 7 64bit and load the bios update on a USB flash drive.
I would not think it's your PSU, it has to be either RAM or motherboard.
Did you Put only One stick of ram in Like I said a few days ago and try and post with that ?
I would bet its your ram that is bad no the board, or it isnt compatible with the board without a bios update. corsair ram is known to act funny in asus boards. I try to avoid it like the plague because I am an asus man. but usually if you have a det dram hang on a asus board its either a: bad ram, B:bad cpu seating or bad cpu, C:need a bios update but cannot do that without the board posting.
OP as far as i can see it really is a RAM Issue here, just spent over 30 mins reading posts in Google about your motherboard. There seems a common problem with that Mobo in recognized some types of ram @ 1.5v or 1.65v etc. There might be a work around fix and that is to try the 1504 Bios, which is a up grade for Ivy Bridge CPU's and Ram Compatibility up grade. As far as i have read about this it seems to work for some people and not for others! The other suggestion would be try your friends ram first to see if it will post and fire up? Now i must say i am no expert on this and just trying to help you out. AJ.
Yep well at this stage then just RMA the board back and get a replacement! But if its possible could you get a different motherboard in return?? Why, because these Sabertooths have so many issues and problems! If you could get a Asrock Extreme 4 or a EX6 instead if its the same price maybe. Its up to you to choose what you want. AJ.
