Alaric
- Dec 4, 2011
- Satan's Colon, US
These are MORE expensive than Intel mainstream on average.
Intel doesn't have PCIe 4.0, either.
Some more MOBO's Gigabyte off EBAY all shipping from Israel all prices are in US Dollars
Gigabyte X570 AORUS ELITE Motherboard CPU AM4 AMD Ryzen DDR4 HDMI GbE LAN RGB – $390.90 US
https://www.ebay.ca/itm/Gigabyte-X5...337505?hash=item3b33ee7ae1:g:vQ8AAOSwWuldEKqK
Gigabyte X570 GAMING X Motherboard CPU AM4 AMD Ryzen DDR4 HDMI RGB LED GbE LAN – $253.90 US
https://www.ebay.ca/itm/Gigabyte-X5...318307?hash=item3b33ee2fe3:g:oHMAAOSwUDldEKPv
Gigabyte X570 AORUS MASTER Motherboard CPU AM4 AMD Ryzen DDR4 WiFi 2.5GbE LAN – $545.90 US
https://www.ebay.ca/itm/Gigabyte-X5...766510?hash=item3d8df6cbae:g:t3wAAOSwDQ1dELy~
Gigabyte X570 AORUS PRO Motherboard CPU AM4 AMD Ryzen DDR4 HDMI RGB LED GbE LAN – $363.90
https://www.ebay.ca/itm/Gigabyte-X5...728813?hash=item3d8df6386d:g:8tsAAOSwq19dELLt
Gigabyte X570 AORUS ULTRA Motherboard CPU AM4 AMD Ryzen DDR4 HDMI GbE LAN WiFi – $418.90 US
https://www.ebay.ca/itm/Gigabyte-X5...756174?hash=item3d8df6a34e:g:RxUAAOSw8VxdELmA
NEW Gigabyte X570 I AORUS PRO WIFI Motherboard CPU AM4 AMD Ryzen DDR4 HDMI WiFi – $318.90 US
https://www.ebay.ca/itm/NEW-Gigabyt...417448?hash=item3b33efb328:g:KJ0AAOSw~G5dEMOb
Any speculation on the B550 boards/chipset? Will it be a PCIe 4.0 B450 equivilent? Has anyone seen anything in the way of pricing for any of these 500 series boards besides the absurdly priced Godlike?
AMD shoudl still easily retain the performance/dollar if the early leaks are true. 3600X is close in performance and $240~ cheaper, especially if the 3600X can run on the non top tier boards well enough. Should make for equal performance at a significantly cheaper price point.
But what worries me is the lag time between the release of these very expensive high end boards and the release of the mid tier and lower tier boards, if it is true latter won't be available until 4th Q. A lot of people considering switching over from Intel might not want to wait that long and will go with whatever new thing Intel is offering.
see the rumor thread. Someone posted up a rumored chart. Its not pretty for the big chips and anything more than a 3800x.I have not heard any talk of B550 boards which are not expected till Q4. Anyone wanting to get in on these new chips will do so with either X570 or X470 i'm afraid. One thing I have not found any info on is how well the X370 chipset will fair at least from the best boards offered …… anyone have any thoughts?
Currently I considering the the ROG X570E Styrix though I may look at the ROG X570 Impact. There were some reservations about the small formfactor boards with the upcoming RYZEN 3000 Chips and am not sure why the reservations.
I hope you are correct, but wont be holding my breath. People really need to take a deep dive I to their needs when buying Zen2 to really get the best bang for the buck. It comes down to if you can actually utilize (not use) the extra cores imo. A $200 difference with cpus for the same core/thread count can be cut in half when using a proper board offering all the chipset has to offer and a capable vrm.I am sure pricing will be better then the links I posted above once more retailers have stock and get them posted.
a ryzen 5 3600 might be a good drop in upgrade for someone on x370 or x470. can't see it being too much power draw for those boards @65watt TDP.
The chart in the ryzen 2 thread makes it look like you should easily be able to upgrade into a ryzen 5 on the older lower end boards making the newer ones not being available less of an issue. Especialy since the budget crowd isn't going to need PCIE 4.0 for awhile.
But do you think a lot of people crossing over from Intel are going to buy the 4xx chipset motherboards to start with when the new CPUs are going to run best on the new 5xx chipset boards?
I'm sorry... at the moment I didnt recall who posted it.Wow, been a member since 2000 and I'm just referred to as "someone" by the OC.com editor.
