Battlefield 2™ v1.01
ReadMe File
Patch Information
- Patch v1.01
Fixed in issue that caused the Multiplayer Browser to become unresponsive.
Fixed an issue where some game controls were not available to be rebound within the Options menu.
Fixed an issue with increasing performance degradation on servers.
Fixed a problem with shader caching on client/host : after the first
map in a rotation, shaders would be loaded on the fly during gameplay.
Fixed a crash with rebinding LMB
Fixed a problem that caused environment mapping to not appear on
reflective surfaces.
Fixed a crash that happened when a client picks up a kit that doesn't
exist anymore.
Fixed a problem with AI when the game was paused for a long time: bots
would become unresponsive and also shoot more accurately.
LOD distances tweaked on certain objects.
Janus67 said:i'm gonna wait to install to see if they fix any of the dropping problems.
dreamtfk said:I keep getting dumped back onto the desktop when I start the game.
dreamtfk said:In the meantime check out this thread regarding BF2 and ranked servers. I thought it was interesting...
http://whutdufuk.com/?post=632558359567343750
Why the heck do you even need a 144hz refresh, that is probably putting huge stress on your video card, try doping down to 100, or 90-95. I have mine at 85. They say anything below 65hz allows you to see out of the corner of your eye you see the screen refreshing thus causing headaches and such.amer1337 said:i have my ingame set to 1024x768 @ 144hz
mage_x said:that guy is wrong, if you filter out everything but ranked servers, filter for populated and not full, then you find TONS of ranked servers that aren't full. also there are several clans that have ranked servers, not just the big companies as he says. I've never had a problem finding a ranked server to join.
Archer36 said:Why the heck do you even need a 144hz refresh, that is probably putting huge stress on your video card, try doping down to 100, or 90-95. I have mine at 85. They say anything below 65hz allows you to see out of the corner of your eye you see the screen refreshing thus causing headaches and such.
