- Feb 1, 2002
- Orlando FL
Anyone else having crashing problems with the new patch? When I start the game it just dumps me back to the desktop, this never happened before I applied the patch.
ninthebin said:Chris64 - are you using a no-cd crack for v1.0? this would cause such problems after the patch install, other than that the patch doesnt change any other files that would be anything to do with video settings etc
the Hz is just to keep the refresh rate high enough so you cant see it, as he said above if your much below 65 you can see the refreshing and it will give you a headache. So higher is better, but 144 makes no sense, absolutely no reason to go that high.TR_B said:Meh ....
That doesn't really makes sense to me: monitor Hz != game FPS
played on non ranked from 5 to 7, then went to ranked to try it out. First try got on a server just filtered by ranked, scrolled down a page and connected. played there from 7pm-1AMPhreakinSyco said:You must play at some odd hours. Anytime after 5 till about midnight = full ranked servers.
Sure several clans have their "own" servers, but you must overestimate the amount of control each clan has over their own servers.
No passwords, No rcon (so unless you can get in the server, its impossible to kick people to make room), no mods, no changing time limits, ticket ratios... basically all you get is your name on the title for $6 a slot.
maxxoverclocker said:all i can say is Patch 1.02 plz! -_-
Motley said:lol, why am I not supprised, this a typical EA "patch" ??
