I need some feedback, total noob here!
This is my first pc build, and of course the first time i overclocked, i built this pc back in september 2011, and yesterday i overclocked it to 4.5 GHZ following this guide
Specs:
CPU: I5-2500K @4.5 GHZ
GPU: GTX 570 PNY
RAM: Corsair Vengeance 2x4 Gb 1600 mhz
MOBO: GYGABYTE Z68X-UD4-B3
CPU COOLER: Hyper 212 EVO with Push/Pull (i added yesterday)
CASE: HAF X
Fans: 2 intake (front, side) 3 exhaust (1 rear, 2 top)
Boot Drive: Vertex 3 120 GB
I followed all the steps on this guide:
-I disabled EIST, C1 AND C5E (something like this), everything else on AUTO.
-I found out my ram was being read as 1300 mhz when it is 1600 mhz, so i changed that....
-Multiple Load "something" (its supposed to be LLC on my BIOS) changed to 5 (50%),
-DRAM Voltage was already on 1.5V (i just tuned off auto and set it manually)
Test and results:
I have only been changing and testing with CPU VCORE Voltage, i started at 1.350 as this guide mentions, and after 30 minutes of Prime95 blend test i stopped it because i realized the CPU VCORE voltage had reached at some point 1.75!! accourding to CPUID:
Then i resetted my pc and changed CPU VCORE voltage all the way down to 1.300, i ran again blend test for little more than 3 hours (i fell asleep), when i wake up, i stopped it again, because CPU VCORE had reached at some point 1.68! according to CPUID:
Then i reset again my pc and changed CPU VCORE voltage to 1.28 (i dont remember last digits...), i ran again the blend test for 5 minutes and stopped it because according to CPUID, my CPU temp had reached at some point 126C!:
I stopped the blend test and closed CPUID, the open it again and everything was normal... so im running the test again now .... 2 hour 30 min so far, everything is fine... just dram voltage MAX is currently 1.63.. value is 1.51.... is this safe?
1.30 max CPU VCORE voltage according to CPUID and value is 1.28, Max core temp is 62C (core 2). CPU-Z says core voltage 1.284....
I stopped this test, dropped cpu vcore .10 again, to 1.275 i think. tried now the intel burn test and it failed: (NO BSOD or FREEZE)
Should i raise the voltage?? my pc didnt froze or bsod....
So, can someone tell me whats going on?? is everything alright?? do i have faulty hardware?? is my hardware damaged?? can i reduce even more the cpu vcore voltage?? do i have to worry about something??? do i need to change something on my BIOS??
Im really a total noob in overclocking......
Thank you for your time and this guide
Specs:
GPU: GTX 570 PNY
CASE: HAF X
Test and results:
