- Jun 4, 2006
- Boston, Mass
Are these temps 'idle' (nothing at all running you dont move the mouse, wait a minute)?
It's a 'featured'
No, I was running Prime95 at like test 14 all cores and moving mouse with monitors on.
It's a 'featured'
C3 state support NO
C6 state support NO
Package C state support. Turn me off
thanks
Awesome Thank you
Got my 2500k to 4.5ghz prime95 blend stable for 12 hours at 1.37v in the bios. Shows as 1.344v in cpu-z. At lower voltages 1.35-1.365 it would fail prime95 blend at 8-9 hours? Whats up with that? That is with spread spectrum, c states and speedstep left on. I'm going to try using the offset voltage now so when it drops down to 1600mhz it will lower the voltage. One core hit 67c, that was my highest temp. Thanks for the guide!
edit: I used these settings which seem to be kind of specific to AsRock boards:
Turbo Boost Power - Manual
Short Duration Power Limit - 250
Long Duration Power Limit - 250
Core current Limit - 250
LLC level 2
So this noob (me) messed something up withing the first two steps and then got an auto shut down twice. Luckily I got back to bios. What I did was bios asus efi utility ez mode. Went to advance mode. Then went to ai tweaker changed my XMp mode to manual as the guide said. Then I was looking for that max turbo option and couldn't find it so I clicked oc tuner just once and that's when I got the auto shutdown twice. ECk getting discouraged by i shall try again. Where is this max turbo when I can change the CPU to 45x100? Even better can anyone show me. Step by step with my bios. I am a noob. Lol
From what I understand with LLC on ASRock boards with lower (bottoming at 1 I assume) the LLC the more voltage is applied for LLC, and the higher the number (3-4-5) the less voltage is applied (sometimes resulting in using less voltage during load than idle - which I can't think of a positive reason for).
Motherboard make and exact model please
(also Cpu and cooler?)
So I take this to mean I should probably just leave it where its at. I'm actually getting very little vdroop as far as I can tell.
Asus P8Z68-v gen 3
I5 2500k
Antec h20 620
Ok so im scared to death to screw something up (first overclock ever :x)
ok so my overcock tuner. would that be HERE in my bios?
as for the ram and voltage i think i can find those. but i may be back xD
I have no idea where the LLC is. lol halp
