Hey fellas,
I did a clean install today (under stock cond. ofcourse) and now I'm running into a bit of an issue. The first time I did this OC I got 4.5Ghz fine but I never set the LLC.
This time I set everything as the guide said and I'm running into some problems. Without my LLC set I'm getting somewhere in the neighborhood of 1.37V which I think is to high so I set LLC and I stay in the 1.359V region. For whatever reason I keep getting blue screened.
I've also notice when I set my timings but leave my DRAM Freq. set to auto my ram shows as 1333, though it's 1600. I have two different brands of ram in my mobo but both have the same exact sspecs. 1.5V, 9-9-9-24
If you're curious of the manufacturers one is GSkill Ripjaws the other two are Intel Pats.
I've tried manually setting the ram to 1600 and 1333, still BSOD. Tried bumping the voltage slightly, still BSOD. I'm not sure how to get back into the 4.5Ghz region without going into the 1.38V region. Any suggestions? If I left something out please let me know!
(EDIT) No matter what I do this cpu wants to pull 1.386V under load, it refuses to go any regardless what the LLC is set to. So far at 4.4Ghz I can get further than I did earlier. But I still BSOD if I change the LLC from 3/5.
(RE-EDIT) I think I might be confusing my self here, am I supposed to be looking at VID or V Core in HWMon?? If I'm looking at Vcore I'm only pulling 1.328V under load.
So if I understand right, the VID is what the cpu is requesting. Since all the cpu is actually getting is a max of 1.36 I am essentially in the clear right? This is with LLC set to auto.
