Well, you can try to RMA the mobo...but honestly, you can probably still populate the slot. Are you talking the lock for the RAM or the socket it's self?
I'd still use it, just beware when you move your case around. You system will always need to be turned off, and after any move you probably want to check to see it's still fully ungaged before powering it back on. It's not the best idea, but our other option is to send it in to Asus for repair...maybe $30-$40 bucks would be my guess.
its the top, yes i have warranty, but I broke in accidently when i put together the computer, its only one port, but i am going to register at asus tommorow
If only the top is broken just get some 5 minute epoxy or JB Weld and use a toothpick to carefully apply it. Slap it back together and I bet that it will work fine.
