- Aug 30, 2004
- Santa Barbara, CA
Your GPU is rather expensive. What kind of monitor are you using?
I don't know what I am doing for sure but this is a very probable possibility.I don't think its overkill, especially with 3x1080p in planning.
Also had a question about fan speed. Seem like I keep seeing topics mention changing max fan speed for the r9 290s from like 40% to 50% or something to that effect. Why would the max fan speed be anything but 100%?
The BIOS isn't a pure idle condition.
The stock heatsink is meh at best, but it works.
Reapplying thermal paste you just clean off the old with some rubbing alcohol and apply a small (a bit smaller than a small pea) dot in the center of the CPU and then clamp the heatsink on.
Guide? Not really. Just route them behind the motherboard.
