Valadar
- Jan 30, 2013
- South Africa
Hi all.
I have a question which hopefully someone can answer.
I recently acquired a Core 2 Quad 9400 CPU which I put in my old MSI P35D3 Platinum motherboard. The problem is that my copy of Windows 7 Ultimate 32 bit never picked up the other 2 processors. I tried overclocking the FSB to see if that would help and still no success. I then tried overclocking the VTT, NB and CPU voltage to within the "white" (acceptable levels) in the BIOS. Then after increasing the FSB to about 400. The computer would not switch on. I had to go somewhere quickly. When I got back I tried to switch the computer on but the display would not come on. I then tried resetting the BIOS by pressing the reset button of the BIOS on the motherboard and then had to keep trying to reset and power on until eventually I got the computer to boot up. Afer this I noticed that my Windows would tell me that my Nvidia graphics card driver would stop responding and need to be restarted, this went on for a while. I thought it was the CPU so I put that in another computer - (Gigabyte DDR2 motherboard) and that computer worked fine with the CPU and showed the correct number of cores with the Q9400. My P35D3 also worked perfectly with my original Core 2 Duo E7300 CPU. However when I put in the Q400 my computer refused to allow the display driver to come on (would not start up) My question is can overclocking the motherboard do damage to the FSB and thus prevent it from working with a CPU that it worked before with?
If anyone has some insight. I would glady appreciate any feedback
