- Jan 12, 2012
LOL no but if you do the flash you should set everything back to default before you do. So if you get a chance I would appreciate it. Just curious to see them.P-States? and you want me to undo what I have just got working?
From what I was reading I might loose some stability with the 9590. I think I might just keep the 1901 bios. I know there is a newer 2002 bios but I can't find any info on it.
Should have left it alone... On my phone typing as I am back to square one even with the settings I used last.
Therer was also something else that I had to check back on. Put your ram in slots 2 and 4, that's what the manual says for dual channel with two sticks. I noticed that very first CPU-z ram shot you were using slot 1.
