Draven, I'll be on, on and off all day. So if you have any questions just post them. The guide is on a Gigabyte board so all the terms may not be the same. It will give you an idea of what you need to know. It will also help that almost all of us that push these Fx's are on Asus boards so we pretty much know them in and out. You can also read this PDF, it's a performance tuning guide from AMD and it's on an Asus motherboard.Well I have to work late tonight. Won't get home till around 7EDT
I'm a bit confused on what you're asking Draven. Are you asking what are the highest max "considered safe" voltage you can use for overclocking or are you asking how high you're Cpu voltage is now when it is stressed?FIRST of many issues is, where can I find the correct max voltages for my CPU?
SO I have scoured the interwebs and have not been able to find settings for my CPU. The only thing I saw was this " voltage = 1.5 for 5.1 ghz,"
darlasxm54 pretty sure it's already at 1.3, that's what was needed to stabilize the ram at 2400mhz.manually set the Cpu/Nb voltage to 1.225 it may help get it stable.
I had mine blowing directly at the CPU socke from the back. Also something along these lines helps as well.
I just Zip tied an 80mm fan to my Vrm/Nb heatsink. It's not pretty, plus it's a Noctua "god why can't they make their fans nicer looking", but it helps!
Wow that's funny, the Redux almost looks like a black and white photo the Industrial PPC isn't bad looking but they really didn't push the boundaries when thinking of colors did they? They're kind of like the Toyota of the fan market, they make great products but are really bland. Except for the 94 Toyota Supra a may be a bit biased though, he he.
