- Feb 5, 2013
- Sydney NSW
- Thread Starter
- #41
Looks like you did case cleaning and helped a lot. Now it would be time to change the compound between the cpu and cpu heatsink since it has likely dried and is not transferring heat to the heatsink to be removed by the heatsink fan. If that does not lower the core temp any, then you have almost zero headroom for overclocking with the current cpu cooler. Just about no room for overclocking in fact.
RGone...
I'll get some Thermal paste on Monday and report back.
for the mean time, could I try to unlock the second core again or is this a bad idea?
My FPS on Modern warfare has shot up to 60+ after the clean, was around 20 before.
how many more degrees can i increase this by? ( core 0 1 temp )
