Cpu idles at 32, full load at 52. that is overclocked at 5ghz. It overclocks up to 5.2ghz but crashes every once in awhile.
Gpu idles at 22, full load at 33. that is at 965 core, 1930 shader, 2106 memory. Its running at 1.138. Questions for you, any reason it wont let me bump that up to 1.15. The option is there, but when I go to change it, it says 1.138 instead of the new voltage.
Yes, the power supply is over kill for now. I plan on dropping in the Ivy bridge when it releases. Also not sure if I'm going to go with another 580 gpu or wait for the new version and get a couple of those. the fans alone draw .45 amps a piece at 12v. So for just the 29 fan, I'm drawing 156w. thats not including the pump, drives, cpu, gpu.... by the time I get the other gpu's I could need it. Better safe than sorry. Plus I would rather run power supply at 60% than 90%. Creates less heat
