- May 15, 2005
- French Mountains
hi'
I would like to have the exact same drives for my raid array,
currently running with one 250gb maxtor 16mb cache, and one WD 250 gb 8 mb cache ... matrix raid 0+1 ...
I'm quite sure that I could get better perf using a pair of disk,
I found a WD 250 gb 16mb cache built for raid .."forgot the ref"
I guess that at first I have to unplug the second drive and plug back one of the new one, then ... ?
put the new drive as first one and plug in the second new drive?
is it going to rebuilt itself?
do I have to enter the matrix raid setup thing to rebuild it?
meaning ctrl+i at startup?
and btw, how can I resize the raid, I would like to change the raid0 from 100gb to 80gb, how to do?
is it possible to do it without loosing data?
how you guys do?
thanks for help
thanks much, much
i686
how you guys do?
thanks for help
thanks much, much
i686
